Thanks @laf. There is the output :
./poller.php -h10 -d -m mempools
Poller
SQL[select `migration` from `migrations` order by `id` desc limit 1 [] 0.27ms]
SQL[select count(*) as aggregate from `migrations` limit 1 [] 0.16ms]
SQL[SELECT version() [] 0.12ms]
Version info:
Commit SHA: 25ee86c9ade5826a4ffff15e4d5f34421394df6a
Commit Date: 1566529196
DB Schema: 2019_07_09_150217_update_users_widgets_settings (140)
PHP: 7.1.33-4+ubuntu16.04.1+deb.sury.org+1
MySQL: 10.0.38-MariaDB-0ubuntu0.16.04.1
RRDTool: 1.5.5
SNMP: NET-SNMP 5.7.3
Updating os_def.cache...
Done
Using authentication for InfluxDB
http transport being used
Override poller modules: mempools
Starting polling run:
SQL[SELECT * FROM `devices` WHERE `disabled` = 0 AND `device_id` = 10 ORDER BY `device_id` ASC [] 0.89ms]
SQL[SELECT * FROM devices_attribs WHERE `device_id` = ? [10] 0.14ms]
Hostname: fwl01
Device ID: 10
OS: forcepoint-os
Resolved IP: X.X.X.X
(forcepoint)
[FPING] /usr/bin/fping -e -q -c 3 -p 500 -t 500 fwl01
array (
'xmt' => '3',
'rcv' => '3',
'loss' => '0',
'min' => '0.33',
'max' => '0.60',
'avg' => '0.48',
'exitcode' => 0,
SQL[INSERT IGNORE INTO `device_perf` (`xmt`,`rcv`,`loss`,`min`,`max`,`avg`,`device_id`,`timestamp`,`debug`) VALUES (:xmt,:rcv,:loss,:min,:max,:avg,:device_id,NOW(),:debug) {"xmt":"3","rcv":"3","loss":"0","min":"0.33","max":"0.60","avg":"0.48","device_id":10,"debug":"[]"} 1.78ms]
SNMP Check response code: 0
Modules status: Global+
OS
Device
#### Load poller module core ####
SNMP['/usr/bin/snmpget' '-v3' '-l' 'authPriv' '-n' "" '-a' 'MD5' '-A' 'PASSWORD' '-u' 'USER' '-x' 'DES' '-X' 'PASSWORD' '-OQnUt' '-m' 'SNMPv2-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/forcepoint' 'udp:HOSTNAME:161' 'sysUpTime.0' 'sysLocation.0' 'sysContact.0' 'sysName.0' 'sysObjectID.0' 'sysDescr.0']
.*.*.0 = 223699783
.*.*.0 = LOCATION
.*.*.0 = [email protected]
.*.*.0 = fwl01
.*.*.0 = .*.4.1.1369.5.2
.*.*.0 = Forcepoint NGFW Firewall/VPN
SNMP['/usr/bin/snmpget' '-v3' '-l' 'authPriv' '-n' "" '-a' 'MD5' '-A' 'PASSWORD' '-u' 'USER' '-x' 'DES' '-X' 'PASSWORD' '-OQnUst' '-m' 'HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/forcepoint' 'udp:HOSTNAME:161' 'snmpEngineTime.0' 'hrSystemUptime.0']
snmpEngineTime.0 = No Such Object available on this agent at this OID
hrSystemUptime.0 = No Such Object available on this agent at this OID
Uptime seconds: 2236998
RRD[update /opt/librenms/rrd/fwl01/uptime.rrd N:2236998]
InfluxDB data:
uptime
array (
'hostname' => 'fwl01',
array (
'uptime' => 2236998.0,
END
Uptime: 25 days 21 hours 23 minutes 18 seconds
SQL[select * from `locations` where (`location` = ?) limit 1 ["LOCATION"] 0.28ms]
>> Runtime for poller module 'core': 0.0777 seconds with 977432 bytes
>> SNMP: [2/0.07s] MySQL: [0/0.00s] RRD: [1/0.00s]
#### Unload poller module core ####
RRD[update /opt/librenms/rrd/fwl01/poller-perf-core.rrd N:0.077714920043945]
InfluxDB data:
poller-perf
array (
'module' => 'core',
array (
'poller' => 0.07771492004394531,
END
OS
Device
#### Load poller module mempools ####
SQL[SELECT * FROM mempools WHERE device_id = ? [10] 0.36ms]
Mempool Physical Memory: 0% RRD[update /opt/librenms/rrd/fwl01/mempool-forcepointos-0.rrd N:U:U]
InfluxDB data:
mempool
array (
'mempool_type' => 'forcepointos',
'mempool_index' => '_blank_',
array (
END
Caught exception: HTTP Code 400 {"error":"unable to parse 'mempool,hostname=fwl01,mempool_type=forcepointos,mempool_index=_blank_ ': invalid field format"}
array (
0 =>
array (
'file' => '/opt/librenms/vendor/influxdb/influxdb-php/src/InfluxDB/Database.php',
'line' => 142,
'function' => 'writePayload',
'class' => 'InfluxDB\\Database',
'type' => '->',
'args' =>
array (
0 =>
array (
0 => 'mempool,hostname=fwl01,mempool_type=forcepointos,mempool_index=_blank_ ',
1 => 'n',
2 => NULL,
1 =>
array (
'file' => '/opt/librenms/includes/influxdb.inc.php',
'line' => 80,
'function' => 'writePoints',
'type' => '->',
'args' =>
array (
0 =>
array (
0 =>
InfluxDB\Point::__set_state(array(
'measurement' => 'mempool',
'tags' =>
array (
'fields' =>
array (
'timestamp' => NULL,
2 =>
array (
'file' => '/opt/librenms/includes/datastore.inc.php',
'line' => 70,
'function' => 'influx_update',
'args' =>
array (
0 =>
array (
'device_id' => 10,
'sysName' => 'fwl01',
'ip' => '
'community' => NULL,
'authlevel' => 'authPriv',
'authname' => 'USER',
'authpass' => 'PASSWORD',
'authalgo' => 'MD5',
'cryptopass' => 'PASSWORD',
'cryptoalgo' => 'DES',
'snmpver' => 'v3',
'port' => 161,
'transport' => 'udp',
'timeout' => NULL,
'retries' => NULL,
'snmp_disable' => 0,
'bgpLocalAs' => NULL,
'sysObjectID' => '.1.3.6.1.4.1.1369.5.2',
'sysDescr' => 'Forcepoint NGFW Firewall/VPN',
'sysContact' => '[email protected]',
'version' => 'Forcepoint NGFW version 6.5.6.21353',
'hardware' => '3305-3-C1',
'features' => NULL,
'location_id' => 4,
'os' => 'forcepoint-os',
'status' => 1,
'status_reason' => '',
'ignore' => 0,
'disabled' => 0,
'agent_uptime' => 0,
'last_polled' => '2020-02-19 09:19:35',
'last_poll_attempted' => NULL,
'last_polled_timetaken' => 1.8900000000000001,
'last_discovered_timetaken' => 1.41,
'last_discovered' => '2020-02-19 09:21:53',
'last_ping' => '2020-02-19 09:19:35',
'last_ping_timetaken' => 0.48,
'purpose' => '',
'type' => 'firewall',
'serial' => 'SERIAL_NUMBER',
'icon' => 'forcepoint.png',
'poller_group' => 0,
'override_sysLocation' => 0,
'notes' => NULL,
'port_association_mode' => 1,
'max_depth' => 0,
'vrf_lite_cisco' => '',
'attribs' =>
array (
'override_device_type' => '1',
'ifName_tune:lo' => 'false',
'discover_route' => '1',
'discover_wireless' => '0',
'poll_wireless' => '0',
'discover_discovery-arp' => '1',
'os_group' => 'forcepoint',
'snmp_max_repeaters' => NULL,
'snmp_max_oid' => NULL,
1 => 'mempool',
2 =>
array (
'mempool_index' => '0',
3 =>
array (
'used' => NULL,
'free' => NULL,
3 =>
array (
'file' => '/opt/librenms/includes/polling/mempools.inc.php',
'line' => 35,
'function' => 'data_update',
'args' =>
array (
0 =>
array (
'device_id' => 10,
'ip' => '
'snmpver' => 'v3',
'port' => 161,
'timeout' => NULL,
'retries' => NULL,
'features' => NULL,
'location_id' => 4,
'status' => 1,
'ignore' => 0,
'disabled' => 0,
'purpose' => '',
'notes' => NULL,
'max_depth' => 0,
'attribs' =>
array (
1 => 'mempool',
2 =>
array (
'rrd_name' =>
array (
0 => 'mempool',
1 => 'forcepointos',
2 => '0',
'rrd_def' =>
LibreNMS\RRD\RrdDefinition::__set_state(array(
'dataSets' =>
array (
0 =>
array (
0 => 'used',
1 => 'GAUGE',
2 => 600,
3 => 0,
4 => 'U',
1 =>
array (
0 => 'free',
1 => 'GAUGE',
2 => 600,
3 => 0,
4 => 'U',
3 =>
array (
'used' => NULL,
'free' => NULL,
4 =>
array (
'file' => '/opt/librenms/includes/polling/functions.inc.php',
'line' => 309,
'args' =>
array (
0 => '/opt/librenms/includes/polling/mempools.inc.php',
'function' => 'include',
5 =>
array (
'file' => '/opt/librenms/poller.php',
'line' => 173,
'function' => 'poll_device',
'args' =>
array (
0 =>
array (
'device_id' => 10,
'ip' => '
'snmpver' => 'v3',
'port' => 161,
'timeout' => NULL,
'retries' => NULL,
'features' => NULL,
'location_id' => 4,
'status' => 1,
'ignore' => 0,
'disabled' => 0,
'purpose' => '',
'notes' => NULL,
'max_depth' => 0,
'attribs' =>
array (
1 => true,
SQL[UPDATE `mempools` set `mempool_used`=?,`mempool_perc`=?,`mempool_free`=?,`mempool_total`=? WHERE `mempool_id` = ? [null,0,null,null,85] 1.02ms]
>> Runtime for poller module 'mempools': 0.0033 seconds with 12712 bytes
>> SNMP: [0/0.00s] MySQL: [2/0.00s] RRD: [2/0.00s]
#### Unload poller module mempools ####
RRD[update /opt/librenms/rrd/fwl01/poller-perf-mempools.rrd N:0.0033431053161621]
InfluxDB data:
poller-perf
array (
'module' => 'mempools',
array (
'poller' => 0.0033431053161621094,
END
### Start Device Groups ###
SQL[select * from `devices` where `devices`.`device_id` = ? limit 1 [10] 0.44ms]
SQL[select * from `device_groups` [] 0.11ms]
SQL[select * from `device_group_device` where `device_id` = ? [10] 0.15ms]
Groups Added:
Groups Removed:
### End Device Groups, runtime: 0.0041s ###
RRD[update /opt/librenms/rrd/fwl01/ping-perf.rrd N:0.48]
InfluxDB data:
ping-perf
array (
array (
'ping' => 0.48,
END
RRD[update /opt/librenms/rrd/fwl01/poller-perf.rrd N:1.144]
InfluxDB data:
poller-perf
array (
'module' => 'ALL',
array (
'poller' => 1.144,
END
SQL[UPDATE `devices` set `uptime`=?,`last_ping`=NOW(),`last_ping_timetaken`=? WHERE `device_id` = ? [2236998,"0.48",10] 1.11ms]
Updating fwl01
Polled in 1.144 seconds
#### Start Alerts ####
SQL[select * from `devices` where `devices`.`device_id` = ? limit 1 [10] 0.4ms]
SQL[select `device_groups`.*, `device_group_device`.`device_id` as `pivot_device_id`, `device_group_device`.`device_group_id` as `pivot_device_group_id` from `device_groups` inner join `device_group_device` on `device_groups`.`id` = `device_group_device`.`device_group_id` where `device_group_device`.`device_id` = ? [10] 0.19ms]
SQL[select exists(select * from `alert_schedule` inner join `alert_schedulables` on `alert_schedule`.`schedule_id` = `alert_schedulables`.`schedule_id` where ((`recurring` = ? and `start` <= NOW() and `end` >= NOW()) or (`recurring` = ? and (`start_recurring_dt` <= date_format(NOW(), '--%d') and (`end_recurring_dt` >= date_format(NOW(), '--%d') or `end_recurring_dt` is null or `end_recurring_dt` = ? or `end_recurring_dt` = ?)) and `start_recurring_hr` <= date_format(NOW(), '%H:%i:%s') and `end_recurring_hr` >= date_format(NOW(), '%H:%i:%s') and (`recurring_day` like CONCAT('%', date_format(NOW(), ''), '%') or `recurring_day` is null or `recurring_day` = ?))) and ((`alert_schedulable_type` = ? and `alert_schedulable_id` = ?) or (`alert_schedulable_type` = ? and 0 = 1))) as `exists` [0,1,"0000-00-00","","","device",10,"device_group"] 0.47ms]
SQL[SELECT DISTINCT a.* FROM alert_rules a
LEFT JOIN alert_device_map d ON a.id=d.rule_id
LEFT JOIN alert_group_map g ON a.id=g.rule_id
LEFT JOIN device_group_device dg ON g.group_id=dg.device_group_id
WHERE a.disabled = 0 AND ((d.device_id IS NULL AND g.group_id IS NULL) OR d.device_id=? OR dg.device_id=?) [10,10] 0.22ms]
#### End Alerts ####
SQL[INSERT IGNORE INTO `perf_times` (`type`,`doing`,`start`,`duration`,`devices`,`poller`) VALUES (:type,:doing,:start,:duration,:devices,:poller) {"type":"poll","doing":"10","start":1582100533.374045,"duration":"1.302","devices":1,"poller":null} 1.16ms]
./poller.php 10 2020-02-19 09:22:14 - 1 devices polled in 1.302 secs
SNMP [3/0.11s]: Get[3/0.11s] Getnext[0/0.00s] Walk[0/0.00s]
MySQL [8/0.01s]: Cell[1/0.00s] Row[-1/-0.00s] Rows[4/0.00s] Column[0/0.00s] Update[2/0.00s] Insert[2/0.00s] Delete[0/0.00s]
RRD [6/0.00s]: Update[6/0.00s] Create [0/0.00s] Other[0/0.00s]
