memory graphs don’t load in the webui.
This happens with existing and newly added devices.
The error is “No Data file for mempool-fortigate-system-0.rrd”.
This is correct, the file is called mempool-fortigate-0.rrd in the filesystem. I don’t know where this additional -system ist coming from. All other graphs work, cpu, temperature, etc.
Any idea how to fix this permanently?
I’m using the latest docker image from librenms/librenms.
librenms:/opt/librenms$ ./validate.php
Component | Version |
LibreNMS | 22.2.1 |
DB Schema | 2021_12_02_113537_ports_stp_designated_cost_change_to_int (234) |
PHP | 7.4.28 |
Python | 3.9.7 |
MySQL | 10.5.9-MariaDB-1:10.5.9+maria~focal |
RRDTool | 1.7.2 |
SNMP | 5.9.1 |
