Migrate frome Teams Webhoot to powerautomate workflow
Microsoft will stop webhooks on MS Teams.
Is it possible to adapt the MS Teams transport to be compatible with Power Automate Webhook?
Here is a clue on how it seems to be solved in Grafana : Update Microsoft Teams to handle workflow responses differently by yuri-tceretian · Pull Request #221 · grafana/alerting · GitHub
Regards
Hi guys we used to fix this issue like replacing the code in
/opt/librenms/LibreNMS/Alert/Transport/Msteams.php
<?php
 * LibreNMS - Microsoft Teams Logic Apps Integration
namespace LibreNMS\Alert\Transport;
use LibreNMS\Alert\Transport;
use LibreNMS\Exceptions\AlertTransportDeliveryException;
class Msteams extends Transport
    protected string $name = 'Microsoft Teams via Logic Apps';
    public function deliverAlert(array $alert_data): bool
        $webhook_url = $this->config['msteam-url'];
        // Construct an Adaptive Card payload
        $data = [
            "type" => "message",
            "attachments" => [
                    "contentType" => "application/vnd.microsoft.card.adaptive",
                    "content" => [
                        "schema" => "http://adaptivecards.io/schemas/adaptive-card.json",
                        "version" => "1.4",
                        "type" => "AdaptiveCard",
                        "body" => [
                                "type" => "TextBlock",
                                "size" => "Medium",
                                "weight" => "Bolder",
                                "text" => "🚨 LibreNMS Alert"
                                "text" => "**Alert:** " . $alert_data['title'],
                                "wrap" => true
                                "text" => "**State:** " . $alert_data['state'],
                                "wrap" => true
                                "text" => "**Message:** " . strip_tags($alert_data['msg']),
                                "wrap" => true
        $payload = json_encode($data, JSON_UNESCAPED_SLASHES | JSON_UNESCAPED_UNICODE);
        $ch = curl_init($webhook_url);
        curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
        curl_setopt($ch, CURLOPT_HTTPHEADER, [
            'Content-Type: application/json',
            'Accept: application/json'
        curl_setopt($ch, CURLOPT_POST, true);
        curl_setopt($ch, CURLOPT_POSTFIELDS, $payload);
        $response = curl_exec($ch);
        $http_code = curl_getinfo($ch, CURLINFO_HTTP_CODE);
        curl_close($ch);
        if ($http_code == 200) {
            return true;
        throw new AlertTransportDeliveryException($alert_data, $http_code, $response, json_encode($data, JSON_PRETTY_PRINT));
    public static function configTemplate(): array
        return [
            'config' => [
                    'title' => 'Logic Apps URL',
                    'name' => 'msteam-url',
                    'descr' => 'Microsoft Logic Apps Trigger URL',
                    'type' => 'text',
            'validation' => [
                'msteam-url' => 'required|url',
and some simplifed and more colorfull version
<?php
        // Define alert color based on severity
        $severity_color = match (strtolower($alert_data['severity'] ?? '')) {
            'critical' => "#FF0000",  // Red for critical
            'warning' => "#FFA500",   // Orange for warning
            default => "#008000"      // Green for normal
        // Convert "State" from number to meaningful status
        $stateText = match ($alert_data['state']) {
            0 => "OK ✅",
            1 => "Warning ⚠️",
            2 => "Critical ❌",
            default => "Unknown"
        // Clean Fault Details - Only extract useful information
        if (!empty($alert_data['faults']) && is_array($alert_data['faults'])) {
            $faultDetails = array_map(function ($fault) {
                return "- " . ($fault['sysDescr'] ?? "Unknown Fault");
            }, $alert_data['faults']);
            $faultDetails = implode("\n", $faultDetails);
        } else {
            $faultDetails = "No additional fault details available.";
        // Construct an Adaptive Card payload with improved formatting
        $data = [
            "attachments" => [
                    "content" => [
                        "$schema" => "http://adaptivecards.io/schemas/adaptive-card.json",
                        "version" => "1.4",
                        "body" => [
                                "size" => "Large",
                                "color" => "Attention",
                                "text" => "🚨 **LibreNMS Alert**",
                                "horizontalAlignment" => "Center"
                                "text" => "**🔔 Alert:** " . $alert_data['title'],
                                "wrap" => true,
                                "color" => "Good"
                                "text" => "**📌 State:** " . $stateText,
                                "wrap" => true,
                                "color" => "Accent"
                                "text" => "**📅 Timestamp:** " . date("Y-m-d H:i:s"),
                                "wrap" => true
                                "text" => "**🆔 Unique-ID:** " . $alert_data['uid'],
                                "wrap" => true
                                "text" => "**⚠️ Severity:** " . ucfirst($alert_data['severity']),
                                "wrap" => true,
                                "text" => "**🔍 Fault Details:**",
                                "wrap" => true,
                                "size" => "Medium",
                                "text" => $faultDetails,
                                "wrap" => true
        curl_close($ch);
            return true;
        return [
            'config' => [
                    'type' => 'text',
            'validation' => [
and version with fixed huge Fault Details message
<?php
            0 => "OK ✅",
            1 => "Warning ⚠️",
            2 => "Critical ❌",
        // Limit the number of fault details shown
        $maxFaults = 5;
        $faultCount = count($alert_data['faults'] ?? []);
            $faultDetails = array_slice($alert_data['faults'], 0, $maxFaults);
            }, $faultDetails);
            $faultDetailsText = implode("\n", $faultDetails);
            if ($faultCount > $maxFaults) {
                $faultDetailsText .= "\n...and " . ($faultCount - $maxFaults) . " more.";
        } else {
            $faultDetailsText = "No additional fault details available.";
        // Construct an Adaptive Card payload with compact formatting
        $data = [
            "attachments" => [
                    "content" => [
                        "version" => "1.4",
                        "body" => [
                                "size" => "Large",
                                "horizontalAlignment" => "Center",
                                "spacing" => "Small"
                                "wrap" => true,
                                "color" => "Good",
                                "wrap" => true,
                                "color" => "Accent",
                                "wrap" => true,
                                "wrap" => true,
                                "wrap" => true,
                                "wrap" => true,
                                "size" => "Medium",
                                "text" => $faultDetailsText,
                                "wrap" => true,
        curl_close($ch);
            return true;
        return [
            'config' => [
                    'type' => 'text',
            'validation' => [
