Migrated LibreNMS CentOS 7 to Rocky Linux 8
When I run the ./validate I get an error “Your database is out of date!” and I run the ./lnms migrate and I get the table already exist. I’m not familiar at all with databases. Do I need to delete some databases?
[[email protected] ~]$ ./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Caching Mac OUI data OK
[[email protected] ~]$ ./validate.php
LibreNMS 21.9.0-10-g8a883140c
DB Schema 2020_06_24_155119_drop_ports_if_high_speed (189)
PHP 7.3.20
Python 3.6.8
MySQL 10.5.12-MariaDB
RRDTool 1.7.0
SNMP NET-SNMP 5.8
[OK] Composer Version: 2.1.8
./lnms migrate
[[email protected] ~]$ ./lnms migrate
  • Application In Production!     *
yes
Migrating: 2020_09_18_230114_create_service_templates_device_group_table
In Connection.php line 692:
SQLSTATE[42S01]: Base table or view already exists: 1050 Table ‘service_templates_device_group’ already exists (SQL: create table service_templates_device_group (service_template_id int unsigned not null, device_group_id
int unsigned not null) default character set utf8mb4 collate ‘utf8mb4_unicode_ci’)
In Exception.php line 18:
In PDOStatement.php line 112:
I was able to fix the problem by dropping the librenms database and importing again.
