I managed to upgrade my mariaDB and MySQL, but now I am having issues with ./lnms migrate
The output of ./validate.php
LibreNMS | 21.12.1
DB Schema | 2021_03_26_014054_change_cache_to_mediumtext (208)
PHP | 7.4.27
Python | 3.8.10
MySQL | 10.3.32-MariaDB-0ubuntu0.20.04.1
RRDTool | 1.7.2
SNMP | 5.8
[OK] Composer Version: 2.2.3
./lnms migrate
after running ./lnms migrate, I get the following errors.
In Connection.php line 703:
SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘librenms.port_group_port’ doesn’t exist (SQL: alter table port_group_port
add constraint port_group_port_port_group_id_foreign foreign key (port_group_id) references port_groups (id) on delete CASCADE)
In Exception.php line 18:
In PDOStatement.php line 117:
I did do a show tables and confirmed that there isn’t a librenms table in there. I also tried running ./daily.sh and am still having the same issue.
Just tried that, same error. Do I need to change CREATE TABLE to librenms.port_groups, or is that probably a permissions error? I am only able to connect to this DB as root, not librenms.
