would it be possible to add CAPsMAN monitoring?
currently if i have CAPsMAN configured and try snmp pooling the CAP devices i get old information from non CAP configuration that is not in use now, all wireless info is on main device CAPsMAN device.
Best Regards,
Kristijan
Did you find a way to solve this? I’m running into the same problem with a CAPsMAN installation.
Buon giorno, qualcuno è riuscito a risolvere e ottenere informazioni snmp da capsman?
Same here. Running several cap ax / wap ax as cap controlled by capsman. Would love to Monitor it
