Mikrotik ports view broken
Since we ran daily.sh overnight it seems the ports view on our Mikrotik devices is broken. Other devices show ports fine. Logs show:
(PDOException(code: HY000): SQLSTATE[HY000]: General error: 1390 Prepared statement contains too many placeholders at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:423)"}
Output from validate.php:
librenms@librenms01:~$ ./validate.php
LibreNMS 25.3.0-63-g43a17931a (2025-03-28T05:35:10+00:00)
DB Schema 2025_03_18_003446_drop_bouncer_tables (327)
PHP 8.3.14
Python 3.10.12
Database MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1
SNMP 5.9.1
[OK] Composer Version: 2.8.6
[FAIL] Some poller nodes have not checked in recently
Inactive Nodes:
nam-test
Similar problem, loading ports page on MikroTik devices suddenly takes very long and sometimes ends with 504 Gateway Time-out or hits PHP Memory limit.
our problem is the same, is it because of the latest update?
Seems like some update broke something.
I tried to reproduce this issue and I could not. Can anyone give me more info or perhaps a full error backtrace?
https://p.libren.ms/view/643c84ab
Full output of my logs here. If you need any further info let me know. Thanks!
select * from portswhereport_id in (1 billion port ids)
The problem is this doesn’t show the full stack trace, only the last file the code ran from, is that all there is?
[previous exception] [object] (PDOException(code: HY000): SQLSTATE[HY000]: General error: 1390 Prepared statement contains too many placeholders at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:423)"}
Yes that’s all that shows in my logs other than the usual polling messages.
is your user an admin?
Yes. Full admin user
I think that it is generally problem with displaying IPv6 neighbours who shares fe80::/64 subnet. And almost all devices share the same fe80::/64 subnet.
Now on each interface of each IPv6 device in ports page I see all ports of other IPv6 enabled devices in LibreNMS. On my setup with ~ 1200 devices, for some random 10 ports MikroTik router it roughly takes 10 ports x 600 neighbours → 6000 ports generated as neighbours which means 35MB of HTML and ~ 500 000 lines of HTML code.
Can someone test this PR? it stops treating link local addresses like they are a network common to ALL interfaces that have IPv6 enabled :smiley:
You will need to run ipv6-addresses discovery after applying the patch.
./discovery.php -h all -m ipv6-addresses
Tried in production, problem is fixed :slight_smile:
I’ve applied the patch and run the discovery but I’m still getting the same error:
This looks to be fixed now. Thanks!
