after the Merge #12642 (Misc cleanups) two days ago my dashboards settings (Availability, Alert and
Eventlog) won’t work any longer . shows (Problem with backend) wenn i click on the dashboard settings.
I tried to change the line from the previous code (from my backup) line 64
app/Http/Controllers/Widgets/WidgetController.php
and then it worked again.
Has someone else noticed that problem already?
Ciao
I’m not seeing the same.
Could you post the actual error from your log?
here the log when i try to click on the dashboard settings.
[2021-03-26 05:40:34] production.ERROR: Trying to get property ‘id’ of non-object (View: /opt/librenms/resources/views/widgets/settings/eventlog.blade.php) {“userId”:1,“exception”:"[object] (Illuminate\View\ViewException(code: 0):
Trying to get property ‘id’ of non-object (View: /opt/librenms/resources/views/widgets/settings/eventlog.blade.php) at /opt/librenms/storage/framework/views/ad666927568fc27cc32b48fc838f70d6b5bf7f29.php:26)
[stacktrace]
#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Engines/PhpEngine.php(60): Illuminate\View\Engines\CompilerEngine->handleViewException()
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Engines/CompilerEngine.php(61): Illuminate\View\Engines\PhpEngine->evaluatePath()
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(139): Illuminate\View\Engines\CompilerEngine->get()
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(122): Illuminate\View\View->getContents()
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(91): Illuminate\View\View->renderContents()
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(436): Illuminate\View\View->render()
#6 /opt/librenms/app/Http/Controllers/Widgets/WidgetController.php(116): Illuminate\View\View->__toString()
#7 /opt/librenms/app/Http/Controllers/Widgets/WidgetController.php(80): App\Http\Controllers\Widgets\WidgetController->formatResponse()
#8 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\Widgets\WidgetController->__invoke()
#9 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction()
#10 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Route.php(254): Illuminate\Routing\ControllerDispatcher->dispatch()
#11 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Route.php(197): Illuminate\Routing\Route->runController()
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(693): Illuminate\Routing\Route->run()
#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#14 /opt/librenms/app/Http/Middleware/LoadUserPreferences.php(30): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#15 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\LoadUserPreferences->handle()
#16 /opt/librenms/app/Http/Middleware/VerifyTwoFactor.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#17 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\VerifyTwoFactor->handle()
#18 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#19 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#20 /opt/librenms/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(44): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#21 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Auth\Middleware\Authenticate->handle()
#22 /opt/librenms/app/Http/Middleware/LegacyExternalAuth.php(42): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\LegacyExternalAuth->handle()
#24 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(78): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#25 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\View\Middleware\ShareErrorsFromSession->handle()
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(121): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(63): Illuminate\Session\Middleware\StartSession->handleStatefulRequest()
#30 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Session\Middleware\StartSession->handle()
#31 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#32 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
#33 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(67): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#34 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\EncryptCookies->handle()
#35 /opt/librenms/app/Http/Middleware/CheckInstalled.php(61): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#36 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\CheckInstalled->handle()
#37 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#38 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(695): Illuminate\Pipeline\Pipeline->then()
#39 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(670): Illuminate\Routing\Router->runRouteWithinStack()
#40 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(636): Illuminate\Routing\Router->runRoute()
#41 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(625): Illuminate\Routing\Router->dispatchToRoute()
#42 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(166): Illuminate\Routing\Router->dispatch()
#43 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#44 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#45 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#46 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#47 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#48 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#50 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#51 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#52 /opt/librenms/vendor/fruitcake/laravel-cors/src/HandleCors.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#53 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fruitcake\Cors\HandleCors->handle()
#54 /opt/librenms/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#55 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle()
#56 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#57 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(141): Illuminate\Pipeline\Pipeline->then()
#58 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#59 /opt/librenms/html/index.php(52): Illuminate\Foundation\Http\Kernel->handle()
#60 {main}
[previous exception] [object] (ErrorException(code: 0): Trying to get property ‘id’ of non-object at /opt/librenms/storage/framework/views/ad666927568fc27cc32b48fc838f70d6b5bf7f29.php:26)
[stacktrace]
#0 /opt/librenms/storage/framework/views/ad666927568fc27cc32b48fc838f70d6b5bf7f29.php(26): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError()
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(107): require(’/opt/librenms/s…’)
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(108): Illuminate\Filesystem\Filesystem::Illuminate\Filesystem\{closure}()
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Engines/PhpEngine.php(58): Illuminate\Filesystem\Filesystem->getRequire()
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Engines/CompilerEngine.php(61): Illuminate\View\Engines\PhpEngine->evaluatePath()
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(139): Illuminate\View\Engines\CompilerEngine->get()
#6 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(122): Illuminate\View\View->getContents()
#7 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(91): Illuminate\View\View->renderContents()
#8 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(436): Illuminate\View\View->render()
#9 /opt/librenms/app/Http/Controllers/Widgets/WidgetController.php(116): Illuminate\View\View->__toString()
#10 /opt/librenms/app/Http/Controllers/Widgets/WidgetController.php(80): App\Http\Controllers\Widgets\WidgetController->formatResponse()
#11 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\Widgets\WidgetController->__invoke()
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction()
#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Route.php(254): Illuminate\Routing\ControllerDispatcher->dispatch()
#14 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Route.php(197): Illuminate\Routing\Route->runController()
#15 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(693): Illuminate\Routing\Route->run()
#16 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#17 /opt/librenms/app/Http/Middleware/LoadUserPreferences.php(30): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#18 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\LoadUserPreferences->handle()
#19 /opt/librenms/app/Http/Middleware/VerifyTwoFactor.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#20 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\VerifyTwoFactor->handle()
#21 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#22 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(44): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#24 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Auth\Middleware\Authenticate->handle()
#25 /opt/librenms/app/Http/Middleware/LegacyExternalAuth.php(42): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\LegacyExternalAuth->handle()
#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(78): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#30 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\View\Middleware\ShareErrorsFromSession->handle()
#31 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(121): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#32 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(63): Illuminate\Session\Middleware\StartSession->handleStatefulRequest()
#33 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Session\Middleware\StartSession->handle()
#34 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#35 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
#36 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(67): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#37 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\EncryptCookies->handle()
#38 /opt/librenms/app/Http/Middleware/CheckInstalled.php(61): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#39 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\CheckInstalled->handle()
#40 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#41 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(695): Illuminate\Pipeline\Pipeline->then()
#42 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(670): Illuminate\Routing\Router->runRouteWithinStack()
#43 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(636): Illuminate\Routing\Router->runRoute()
#44 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(625): Illuminate\Routing\Router->dispatchToRoute()
#45 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(166): Illuminate\Routing\Router->dispatch()
#46 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#47 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#48 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#49 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#50 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#51 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#52 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#53 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#54 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#55 /opt/librenms/vendor/fruitcake/laravel-cors/src/HandleCors.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#56 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fruitcake\Cors\HandleCors->handle()
#57 /opt/librenms/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#58 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle()
#59 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#60 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(141): Illuminate\Pipeline\Pipeline->then()
#61 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#62 /opt/librenms/html/index.php(52): Illuminate\Foundation\Http\Kernel->handle()
#63 {main}
Ok I think I know why it breaks now, can’t figure out why I’m not seeing it tho.
Is Laravel causing this? Do i have a different version than others? I have no clue. I am far behind about all this
Yep I tested your new code here and It works again. Thanx for fixing this . Have a nice weekend.
system
Closed
29 September 2021 14:39
#10
