Mismatched PHP Versions
If it’s an issue with the WebUI then please consider including the browser version you are using.
I’m running into an issue where the GUI “About” page is showing a different PHP version than the validate.php script when running from the CLI.
About Page:
Version 1.33-335-g7e03905e6 - Tue Jan 09 2018 15:47:33 GMT-0500
DB Schema #228
Web Server Apache
PHP 5.4.45
MySQL 5.6.35-81.0
RRDtool 1.4.7
CLI validate.php
LibreNMS 1.33-338-gd515f5043
DB Schema 228
PHP 7.1.10
MySQL 5.6.35-81.0
RRDTool 1.4.7
SNMP NET-SNMP 5.5
I very much doubt this is a librenms thing.
If you are running php-fpm, have you restarted it since a php update maybe?
Hi Laf,
Yep it was just our system. We use SCL to run multiple versions of PHP on our systems and something didn’t like when I switched to 7.1. Got it resolved though.
Thanks!
