I’m new to LibreNMS and am in the process of converting out of Observium to LibreNMS. One thing I noticed is that the Description field from Device Settings --> Description isn’t showing up in the Overview tab when you bring up the device.
Is this a known issue or is it showing up somewhere else?
Laf- I had another thought about this feature request. Can you set it to only show if there’s data in the description field? The line item itself wouldn’t show up if there’s no data in the description field for the device.
