Hi I’ve just installed LibreNMS and am using the docker containers using docker-compose. It’s up and going but I seem to be missing a bit of graphs for a couple of devices. This seems to be happening across the board for multiple devices / makes / models. It seems to be present in graphs / health areas/ connected client ext.. I also noticed that my mini graphs at the top right are not working either
An output of my validate.php is below
LibreNMS | 23.2.0 (2023-03-24T19:45:26+08:00)
DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (248)
PHP | 8.1.17
Python | 3.10.10
Database | MariaDB 10.5.20-MariaDB-1:10.5.20+maria~ubu2004
RRDTool | 1.7.2
SNMP | 5.9.3
[OK] MySQl and PHP time match
[OK] Redis is functional
is there something I have overlooked during the install. I have also noticed that sometimes when I refresh it will switch back to light mode even though I have selected dark mode. Unsure if this is a known or common issue with the docker installation. I have tested this on multiple browsers
Any help or tips would be much appreciated
