Missing Health>Storage results
Since the new update i’ve lost all results under Health>Storage with a ‘No results found!’. I have results for all others such as Memory, Processor, Fanspeed, temperature ect, just Storage is empty now.
If i go to my any specific devices page they show their own storage correctly.
$ ./validate.php
LibreNMS 25.5.0 (2025-05-17T01:51:05+10:00)
DB Schema 2025_05_03_152418_remove_invalid_sensor_classes (338)
PHP 8.3.21
Python 3.11.12
Database MariaDB 10.11.11-MariaDB
RRDTool 1.9.0
SNMP 5.9.4.pre2
[OK] Composer Version: 2.8.9
[OK] Redis is functional
[INFO] fping FAILURES can be ignored if running LibreNMS in a jail without ::1. You may want to test it manually: fping ::1
[FAIL] /usr/local/sbin/fping6 could not be executed. /usr/local/sbin/fping6 must have CAP_NET_RAW capability (getcap) or suid. Selinux exclusions may be required.
(/usr/local/sbin/fping6: can’t create socket (must run as root?))
[WARN] Log rotation not enabled, could cause disk space issues
sudo cp /usr/local/www/nginx/misc/librenms.logrotate /etc/logrotate.d/librenms
Modified Files:
dist/librenms.cron
includes/port-descr-parser.inc.php
This has now been resolved, there was a non-existing device which A.I took me down a path in SQL to resolve this. And now the storage page is working.
