Missing ports from Device mikrotik and VSOL EPON OLT
Hi everyone,
I’m facing an issue in LibreNMS with some of my devices:
I have added multiple MikroTik routers and VSOL OLTs in LibreNMS.
Issue:
Some interfaces/ports are missing in LibreNMS, even though those ports are actually live and actively used in production.
Details:
  • When I first add the device, all interfaces appear correctly.
  • After some time, certain ports disappear from LibreNMS.
  • This does NOT happen on all MikroTik or all VSOL OLT devices — only on some specific devices.
  • The missing interfaces are operational and passing traffic.
  • Earlier, in SNMP settings, I selected ifIndex.
  • Later, I changed it to ifName, but the issue still persists.
I’m not sure why this is happening.
Has anyone faced a similar issue?
Could this be related to:
  • SNMP polling
  • Interface indexing changes
  • MikroTik dynamic interfaces
  • OLT firmware behavior
  • LibreNMS interface filtering/cleanup settings?
Any guidance on troubleshooting steps would be greatly appreciated.
Output of ./Validate-
LibreNMS 26.2.0 (2026-02-16T17:43:17+05:30)
DB Schema 2026_02_13_000000_change_stp_top_changes_to_unsigned_int (365)
PHP 8.3.6
Python 3.12.3
SNMP 5.9.4.pre2
[OK] Composer Version: 2.9.5
[FAIL] Some RRD files have the incorrect step. 249/43077
lnms maintenance:rrd-step all
RRD files with incorrect step:
smokeping/network/103_92_44_11.rrd: step is 60, should be 300
smokeping/network/54_64_74_52.rrd: step is 60, should be 300
smokeping/network/54_64_74_68.rrd: step is 60, should be 300
smokeping/network/55_65_75_51.rrd: step is 60, should be 300
smokeping/network/55_65_75_65.rrd: step is 60, should be 300
smokeping/network/55_65_75_111.rrd: step is 60, should be 300
smokeping/network/55_65_75_179.rrd: step is 60, should be 300
smokeping/network/52_62_72_81.rrd: step is 60, should be 300
smokeping/network/54_64_74_104.rrd: step is 60, should be 300
smokeping/network/55_65_75_93.rrd: step is 60, should be 300
smokeping/network/52_62_72_83.rrd: step is 60, should be 300
smokeping/network/45_114_48_86.rrd: step is 60, should be 300
smokeping/network/55_65_75_91.rrd: step is 60, should be 300
smokeping/network/55_65_75_63.rrd: step is 60, should be 300
smokeping/network/54_64_74_13.rrd: step is 60, should be 300
and 234 more…
