Hello!
made
su - librenms
git pull
./daily.sh
but validate fails and wrote recomendationto fix DB. But new error that tables is missing
[FAIL] Database: extra table (port_out_measurements)
[FAIL] Database: extra table (voltage)
[FAIL] We have detected that your database schema may be wrong, please report the following to us on Discord (https://t.libren.ms/discord) or the community site (https://t.libren.ms/5gscd):
SQL Statements:
ALTER TABLE hrDevice CHANGE device_id device_id int unsigned NOT NULL ;
ALTER TABLE hrDevice CHANGE hrDeviceErrors hrDeviceErrors int NOT NULL DEFAULT ‘0’ ;
ALTER TABLE hrDevice DROP INDEX device_id;
ALTER TABLE hrDevice ADD INDEX hrdevice_device_id_index (device_id);
ALTER TABLE juniAtmVp CHANGE juniAtmVp_id juniAtmVp_id int unsigned NOT NULL ;
ALTER TABLE juniAtmVp ADD port_id int unsigned NOT NULL AFTER juniAtmVp_id;
ALTER TABLE juniAtmVp CHANGE vp_id vp_id int unsigned NOT NULL ;
ALTER TABLE juniAtmVp DROP interface_id;
ALTER TABLE juniAtmVp ADD INDEX juniatmvp_port_id_index (port_id);
DROP TABLE bgppeers;
DROP TABLE bgppeers_cbgp;
DROP TABLE ciscoasa;
DROP TABLE cmpmempool;
DROP TABLE current;
DROP TABLE dbschema;
and 11 more…
^C
Session terminated, terminating shell… …terminated.
saho@SERV80:/opt/librenms$ mysql -ulibrenms -ppassword -D librenms
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 11503
Server version: 10.0.38-MariaDB-0ubuntu0.16.04.1 Ubuntu 16.04
Copyright © 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type ‘help;’ or ‘\h’ for help. Type ‘\c’ to clear the current input statement.
MariaDB [librenms]> ALTER TABLE hrDevice CHANGE device_id device_id int unsigned NOT NULL ;
DROP TABLE current;
Query OK, 0 rows affected (36.48 sec)
Records: 0 Duplicates: 0 Warnings: 0
MariaDB [librenms]> ALTER TABLE hrDevice CHANGE hrDeviceErrors hrDeviceErrors int NOT NULL DEFAULT ‘0’ ;
Query OK, 0 rows affected (0.18 sec)
MariaDB [librenms]> ALTER TABLE hrDevice DROP INDEX device_id;
Query OK, 0 rows affected (11.34 sec)
MariaDB [librenms]> ALTER TABLE hrDevice ADD INDEX hrdevice_device_id_index (device_id);
Query OK, 0 rows affected (7.34 sec)
MariaDB [librenms]> ALTER TABLE juniAtmVp CHANGE juniAtmVp_id juniAtmVp_id int unsigned NOT NULL ;
Query OK, 0 rows affected (24.80 sec)
MariaDB [librenms]> ALTER TABLE juniAtmVp ADD port_id int unsigned NOT NULL AFTER juniAtmVp_id;
Query OK, 0 rows affected (11.26 sec)
MariaDB [librenms]> ALTER TABLE juniAtmVp CHANGE vp_id vp_id int unsigned NOT NULL ;
Query OK, 0 rows affected (30.98 sec)
MariaDB [librenms]> ALTER TABLE juniAtmVp DROP interface_id;
Query OK, 0 rows affected (13.00 sec)
MariaDB [librenms]> ALTER TABLE juniAtmVp ADD INDEX juniatmvp_port_id_index (port_id);
Query OK, 0 rows affected (8.32 sec)
MariaDB [librenms]> DROP TABLE bgppeers;
Query OK, 0 rows affected (3.55 sec)
MariaDB [librenms]> DROP TABLE bgppeers_cbgp;
Query OK, 0 rows affected (2.87 sec)
MariaDB [librenms]> DROP TABLE ciscoasa;
Query OK, 0 rows affected (6.98 sec)
MariaDB [librenms]> DROP TABLE cmpmempool;
Query OK, 0 rows affected (0.00 sec)
MariaDB [librenms]> DROP TABLE current;
MariaDB [librenms]> DROP TABLE dbschema;
Query OK, 0 rows affected (6.26 sec)
MariaDB [librenms]> quit
Bye
saho@SERV80:/opt/librenms$ sudo ./validate.php
| LibreNMS | 1.68 |
| DB Schema | 2020_09_24_000500_create_cache_locks_table (176) |
| PHP | 7.4.11 |
| Python | 3.5.2 |
| MySQL | 10.0.38-MariaDB-0ubuntu0.16.04.1 |
| RRDTool | 1.5.5 |
| SNMP | NET-SNMP 5.7.3 |
In Connection.php line 671:
SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘librenms.bgppeers’ doesn’t exist (SQL: SHOW INDEX FROM bgpPeers)
In PDOStatement.php line 131:
In PDOStatement.php line 129:
