Monitor and graph the CPU's temperature of pfsense firewall
hey guys im trying to monitor and graph the temperature for my pfsense. but seems like im not ablte to get the value , or interpret it in an adequate manner. can someone help??
running the following command :
php discovery.php -h pf1 -d -v -m applications i get :
Applications: SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v3’ ‘-l’ ‘authPriv’ ‘-n’ “” ‘-a’ ‘SHA’ ‘-A’ ‘’ ‘-u’ ‘manager’ ‘-x’ ‘AES’ ‘-X’ '**’ ‘-OQUs’ ‘-m’ ‘NET-SNMP-EXTEND-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/pfsense’ ‘-t’ ‘5’ ‘-r’ ‘10’ ‘udp:pf1:161’ ‘nsExtendStatus’]
nsExtendStatus.“cpuTemp0” = active
nsExtendStatus.“cpuTemp1” = active
also running other command : php discovery.php -h pf1 -d -m sensors
Temperature: SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v3’ ‘-l’ ‘authPriv’ ‘-n’ “” ‘-a’ ‘SHA’ ‘-A’ ‘PASSWORD’ ‘-u’ ‘USER’ ‘-x’ ‘AES’ ‘-X’ ‘PASSWORD’ ‘-Osqn’ ‘-m’ ‘LM-SENSORS-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/pfsense’ ‘-t’ ‘5’ ‘-r’ ‘10’ ‘udp:HOSTNAME:161’ ‘lmTempSensorsDevice’]
..4.1.2.1.2 No Such Object available on this agent at this OID
Invalid snmp_walk() data = .1.3.6.1.4.1.2021.13.16.2.1.2 No Such Object available on this agent at this OID
$ php validate.php
LibreNMS 22.12.0-6-gcf3f69e (2023-01-02T14:47:17+01:00)
DB Schema 2022_08_15_084507_add_rrd_type_to_wireless_sensors_table (248)
PHP 8.1.13
Python 3.9.16
Database MariaDB 10.5.16-MariaDB
SNMP 5.9.1
[OK] Composer Version: 2.5.1
[OK] MySQl and PHP time match
i’ve created this small script and set it smpd.config
#!/bin/sh
/sbin/sysctl dev.cpu | /usr/bin/awk ‘/temperature/ {print $2;}’
if executed this is the result :
sh gettemps.sh
46.0C
46.0C
46.0C
46.0C
