Dear all Member,
Hope you all doing well.
Actually i added to my LibreNMS system. everything seems working fine. No succes with bind9, no snmp output result and graph exist with question mark and nan reuslt.
The configuration:
/etc/snmp/bind file=
my $call_rndc=1;
my $rndc=’/usr/sbin/rndc’;
my $stats_file=’/var/named/data/named_stats.txt’;
my $zero_stats=1;
my $agent=0;
my $missing=0;
named.conf file= statistics-file “/var/named/data/named_stats.txt”;
directory “/var/named”;
The bind App is with a question mark.
No bind user created and the snmpd.conf file contain : extend bind /etc/snmp/bind
snmpwalk -v2c -c public localhost NET-SNMP-EXTEND-MIB::nsExtendOutput2Table
NET-SNMP-EXTEND-MIB::nsExtendOutput2Table = No more variables left in this MIB View (It is past the end of the MIB tree)
./bind
123,32,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,5,0,0,0,0,0,0,0
626,399,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,13,0,0,0,0,0,0,0
160,0,0,0,0,0,156,0,0,154,0,156,2,0,0,136,4,0,160,0,0,0
215,825,215,808,0,0,0,0,166,0,216,18,174,174,0,16,3,601,418,0,1,0,1046,0
5887,27,587,244,0,111,880,583,1105328,443096,443152,655360,133120,133120
649,500,0,0,0,0,0,0,34,0,0,0,19,0,0,0,0,0,0,160,0,0,0,0,64,0,0,0,0,0,0,0,0,0,2,0,0,0,0,0,0,0,0,0,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,0,0,0,0,0,0,0,0
2042,1121,2042,680
171,717,54,116,1,164,710,61,115,0,0,0,0,0,0,0,0,164,51,710,114,11,0,0,0,0,0,0,0,0,0,7,7,4,1,1
ll
-rwxr-xr-x. 1 root root 22030 May 22 10:12bind
I followed the topic below but with no luck:
Thanks in advance.
Reagrds,
Franks
