Hello. I would like to monitor and alarm on the state of my IPSec tunnels on my Ubiquiti Infinity router and I was hoping that someone could point me in the right direction. Any support would be greatly appreciated.
Thank you.
Thank you.
Hi Mate,
So what i have done is that i used the “Top Interfaces” widget and selected interface type “tunnel”.
You can also group the ipsec ports that have been created on the device and then create a “Top Interfaces” widget and select the port group that you just created.
I hope i could help
