Monitoring Chronyd still produces errors
Hello All,
Still can’t get chronyd to work. Everything seems to be configured correctly according to this
I get the following errors:
Application: chronyd, app_id=22SNMP[‘/usr/bin/snmpget’ ‘-v1’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-m’ ‘NET-SNMP-EXTEND-MIB’ ‘-M’ ‘/opt/librenms/mibs’ ‘-t’ ‘2’ ‘udp:HOSTNAME:161’ ‘nsExtendOutputFull.7.99.104.114.111.110.121.100’]
Exitcode: 2
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: NET-SNMP-EXTEND-MIB::nsExtendOutputFull.“chronyd”
Error in packet
chronyd:-2:Empty return from snmp_get.
Any help you are able to provide is greatly appreciated.
do you have
extend chronyd /etc/snmp/chrony
in your snmpd.conf and this file https://raw.githubusercontent.com/librenms/librenms-agent/master/snmp/chrony in place?
It needs to be executable, otherwise, it won’t work.
Yes, I do. When I run the script locally it works and gets the output.
I am running it on ubuntu not sure if there is anything more that could be done.
Not sure how to go about troubleshooting these type of errors.
Error in packet
