It would be great if LibreNMS could
a) Discover all devices (VMs) on cloud infrastructure (Azure, AWS, etc) and
b) fetch the state (on or off) on a regular basis.
This would be a good first start to extend then monitoring upon.
It already can. If you just want to fetch the state you could do a ping only check.
Otherwise you can install an snmp daemon on the VMs and have librenms poll your VMs
This only works for VMs but not for all the services available on such infrastructures like e.g Azure Virtual WAN or all the DB-as-a-service products. That’s why I wrote that my list is just an “easy start” to build upon. The end result should then clearly be about a lot more.
