Monitoring Quagga/BGP Sessions
Is anyone familiar with trying to monitor BGP sessions on a linux server running Quagga?
I don’t think LibreNMS will pull in BGP from Quagga by default, based on testing I’ve done.
I’d appreciate any ideas/suggestions for this.
Thanks,
J
I have no experience with quagga whatsoever but have you tried enabling snmp support?
https://www.nongnu.org/quagga/docs/docs-multi/SNMP-Support.html
@laf or anyone with history in the development of LibreNMS know if the link below is something thats been incorporated into or dropped in the current design? I know this is super old. I am just unsure if I enable SNMP monitoring within Quagga if I need to do anything else within LibreNMS to pick things up or if it will be able to pull things in.
https://gitlab.ctwug.za.net/librenms/librenms/commit/22f8cfe8e011a6be335aabd35dc6e1b2635f66d3
Thanks,
J
That just looks like a link to a mirror of our main repo.
Why don’t you just enable snmp and see what you get?
i am getting same issue.
LibreNMS couldn’t detect any quagga BGP routing. i am running Debian 9.
You have to recompile quagga with snmp support due to the openssl licence.
Thanks @trs80
You’re right. Quagga needs to be enabled snmpd.
I am finding a way to add support for quagga on Debian 9. Anyone has idea how to do this?
I was able to get support once I enable SNMP (recompiled quagga with snmp) and setup agentx support.
What does your quagga config look like?
Following these steps for agentx seemed to work for me.
-J
