Monitoring StrongSwan ipsec instance
StrongSwan currently does not have any snmp agent support.
But maybe it isn’t to much work to add an extension script to snmp agent to expose some of this data?
Is there any “standard” mib that is suitable to try and populate?
Would it make sense to run this?
Or just add extend ipsec /usr/bin/ipsec statusall and then add logic to parse this in LNMS?
But proper mibs would be more useful for the wider community.
Any input appreciated!
