I’m working on a patch to add more tags to the influxdb export:
device_ip - The IP address of the device
device_serial - The serial number of the device
device_model - The hardware/model of the device
module - The name of the module that collected the metric
maintenance - Whether the device is under maintenance (1 or 0)
further, it adds the device group as tags like this:
a device in groups “Datacenter” and “Core-Switches” will receive tags group_Datacenter and group_Core_Switches.
I’m not quite sure yet if I like this solution and I’m open for ideas and comments.
Here is the updated documentation:
Here is the patch against version 26.1.1:
FROM librenms/librenms:26.1.1
RUN apk update && apk add patch
# influxdb add fields
RUN wget https://github.com/shrank/librenms_patches/pull/18.patch && patch -p 1 -f < 18.patch ; exit 0 #ignore errors
RUN lnms translation:generate
The main thing that I would want is the device groups.
What would you think could be a solution for that?
I can’t use a hybrid API based approach(Like Zabbix does) because the grafana server and the librenms servers live in separate domains which allow for one way dataflow only(Librenms->Influxdb)
