Hello everyone,
I am currently facing an issue with my LibreNMS server. Initially, everything was working perfectly, but recently, the server has been disconnecting intermittently. I access the server via mRemoteNG, and every 2-5 minutes, I experience disconnections, along with a “404 Not Found” error message appearing on the LibreNMS dashboard at the same time.
However, when I access the server directly through Hyper-V Manager, everything seems to be running fine without any disconnections. This issue only occurs when using mRemoteNG.
Here’s a summary of the troubleshooting steps I’ve already tried:
- Checked and verified that the server disk space and memory usage are not overloaded.
- Reviewed the MariaDB logs, and there doesn’t seem to be any obvious error related to the disconnections.
- Checked MySQL and MariaDB configurations (timeouts, connections, etc.), but the issue persists.
- Attempted to optimize and repair the LibreNMS database, which didn’t resolve the issue.
- Ensured all required services (MariaDB, Apache, etc.) are running smoothly and have not been crashing.
Despite these efforts, the disconnections and 404 errors continue. Can anyone suggest further steps or configurations I might be missing to resolve this issue?
Steps to Reproduce:
- Use mRemoteNG to access the LibreNMS server.
- Wait for 2-5 minutes.
- Observe the disconnection and 404 error on the LibreNMS dashboard.
Output of ./validate.php:
librenms@shsc-nms04:~$ ./validate.php
| LibreNMS | 25.1.0 (2025-01-17T16:28:40+11:00) |
| DB Schema | 2024_11_22_135845_alert_log_refactor_indexes (310) |
| PHP | 8.3.17 |
| Python | 3.10.12 |
| Database | MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1-log |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.8.5
[OK] Redis is functional
If you need additional logs or details, please let me know.
Thank you for your help!
