i’ve implemented the new ova Librenms-centos-7.6, and i’ve change the timezone for corresponding to my country (Europe/Paris) after that i run ./validate.php and all the time i’ve this issue
[OK] Composer Version: 1.10.1
[FAIL] Database: incorrect column (notifications/datetime)
[FAIL] Database: incorrect column (users/created_at)
[FAIL] We have detected that your database schema may be wrong, please report the following to us on Discord (https://t.libren.ms/discord) or the community site (https://t.libren.ms/5gscd):
SQL Statements:
ALTER TABLE notifications CHANGE datetimedatetime timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:00’ ;
ALTER TABLE users CHANGE created_atcreated_at timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:01’ ;
hello _dGs, exactaly i’ve modify the time zone with following command :
timedatectl set-timezone
also modify the file php.ini
after that i relaunch the ./validate.php after that the result mention that i have swedish mysql or something like that and i modify for utf 8, unfortunately i get it the following result :
i’ve try this two sql statement fix but it doesn’t work at all
Ok so I have downloaded the same ova and did as librenms:
sudo timedatectl set-timezone Europe/Paris
sudo vi /etc/php.ini (date.timezone = Europe/Paris)
sudo reboot now
./validate.php
LibreNMS | 1.56
DB Schema | 2019_09_05_153524_create_notifications_attribs_index (141)
PHP | 7.2.22
MySQL | 5.5.64-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[FAIL] MySQL Database collation is wrong: latin1 latin1_swedish_ci
Check https://t.libren.ms/-zdwk for info on how to fix.
SQL Statements:
ALTER TABLE `notifications` CHANGE `datetime` `datetime` timestamp NOT NULL DEFAULT '1970-01-02 00:00:00' ;
ALTER TABLE `users` CHANGE `created_at` `created_at` timestamp NOT NULL DEFAULT '1970-01-02 00:00:01' ;
[FAIL] The poller (localhost.localdomain) has not completed within the last 5 minutes, check the cron job.
Check the cron job to make sure it is running and using discovery-wrapper.py
echo 'ALTER DATABASE librenms CHARACTER SET utf8 COLLATE utf8_unicode_ci;' | mysql -p -u librenms librenms
