MX960 with VC setup not getting processor info
We have a MX960 setup in at Virtual Chassis konfig and everything gets polled except for det processors. Is this an error in librenms or the snmp setup on the system?
Setup is running: Juniper JunOS 21.4R3-S3.4 on both MX960s.
from poller debug
Load poller module processors
Attempting to initialize OS: junos
OS initialized: LibreNMS\OS\Junos
SQL[SELECT * FROM processors WHERE device_id=? [63] 0.77ms]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQn’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/junos’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.2.1.25.3.3.1.2.0’ ‘.1.3.6.1.2.1.25.3.3.1.2.1’ ‘.1.3.6.1.2.1.25.3.3.1.2.2’ ‘.1.3.6.1.2.1.25.3.3.1.2.3’]
Exitcode: 1
.1.3.6.1.2.1.25.3.3.1.2.0: Unknown Object Identifier (Index out of range: 0 (hrDeviceIndex))
array (
Processor: 0%
RRD[last 62.xxx.xxx.xx/processor-hr-0.rrd --daemon 212.112.xxx.xxx:42217]
RRD[update 62.xxx.xxx.xx/processor-hr-0.rrd N:0 --daemon 212.112.xxx.xxx:42217]
Processor: 0%
RRD[last 62.xxx.xxx.xx/processor-hr-1.rrd --daemon 212.112.xxx.xxx:42217]
RRD[update 62.xxx.xxx.xx/processor-hr-1.rrd N:0 --daemon 212.112.xxx.xxx:42217]
Processor: 0%
RRD[last 62.xxx.xxx.xx/processor-hr-2.rrd --daemon 212.112.xxx.xxx:42217]
RRD[update 62.xxx.xxx.xx/processor-hr-2.rrd N:0 --daemon 212.112.xxx.xxx:42217]
Processor: 0%
RRD[last 62.xxx.xxx.xx/processor-hr-3.rrd --daemon 212.112.xxx.xxx:42217]
RRD[update 62.xxx.xxx.xx/processor-hr-3.rrd N:0 --daemon 212.xxx.143.xxx:42217]
Runtime for poller module ‘processors’: 0.0428 seconds with 63848 bytes
SNMP: [1/0.04s] MySQL: [1/0.01s] RRD: [10/0.00s]
Unload poller module processors
