It seams that on 5.7.20 MySQL Community Server (also had this on earlier versions) there is a problem with Maintenance Scheduling.
When trying to add a Maintenance record, a following error occurs:
MySQL Error: Incorrect date value: ‘0000-00-00’ for column ‘start_recurring_dt’ at row 1 (INSERT INTO alert_schedule (recurring,start,end,start_recurring_dt,end_recurring_dt,start_recurring_hr,end_recurring_hr,recurring_day,title,notes) VALUES (‘0’,‘2018-01-22 13:35’,‘2018-01-22 14:35’,‘0000-00-00’,’’,‘00:00:00’,‘00:00:00’,’’,‘test’,’’))
One of the fixes i see is making a change in “html/includes/forms/schedule-maintenance.inc.php”, but I am not sure if it doesn’t break anything in MariaDB:
//$start_recurring_dt = ‘0000-00-00’;
$start_recurring_dt = ‘1970-01-02’;
//$end_recurring_dt = null;
$end_recurring_dt = ‘1970-01-02’;
[FAIL] You have not set sql_mode=’’ in your mysql config.
[FIX] Set sql-mode=’’ in your mysql config file in the [mysqld] section.
[FAIL] Database: extra table (plugin_config_rules)
SQL Statements:
DROP TABLE plugin_config_rules;
just try to delete NO_ZERO_DATE and NO_ZERO_IN_DATE, from the sql_mode.
for example , add this line below in the mysqld.cnf and restart the service:
sql_mode = ONLY_FULL_GROUP_BY,STRICT_TRANS_TABLES,ERROR_FOR_DIVISION_BY_ZERO,NO_ENGINE_SUBSTITUTION
