my mysql applications graphs only show NaN
Other applications on same server (apache, postfix) work fine.
Here ist the output of validate.php:
bash-4.2$ ./validate.php
Component Version LibreNMS 21.8.0-265-g4d7a5dd DB Schema 2021_25_01_0129_isis_adjacencies_nullable (216) PHP 7.3.30 Python 3.6.8 MySQL 10.5.12-MariaDB RRDTool 1.4.8 SNMP NET-SNMP 5.7.2 ==================================== [OK] Composer Version: 1.8.6
And the output of the poller.php:
bash-4.2$ ./poller.php -h 8
LibreNMS Poller
Starting polling run:Hostname: iliasweb01
Device ID: 8
OS: linux
Resolved IP: 192.168.1.131
(unix)Load poller module core
Uptime: 324 days 39 minutes 40 seconds
Runtime for poller module ‘core’: 0.0278 seconds with 51224 bytes
SNMP: [2/0.03s] MySQL: [0/0.00s] Graphite: [1/0.00s] RRD: [1/0.00s]Unload poller module core
Load poller module availability
Availability:
1 day : 100%
7 days : 100%
30 days : 100%
365 days : 100%Runtime for poller module ‘availability’: 0.0054 seconds with 39352 bytes
SNMP: [0/0.00s] MySQL: [5/0.00s] Graphite: [5/0.00s] RRD: [5/0.00s]Unload poller module availability
Module [ unix-agent ] disabled globally.
Load poller module os
Generic
Hardware: Generic x86 64-bit
OS Version: 3.10.0-1127.19.1.el7.x86_64
OS Features:
Serial:Runtime for poller module ‘os’: 0.0017 seconds with 97976 bytes
SNMP: [0/0.00s] MySQL: [0/0.00s] Graphite: [1/0.00s] RRD: [1/0.00s]Unload poller module os
Load poller module ipmi
Runtime for poller module ‘ipmi’: 0.0007 seconds with 2992 bytes
SNMP: [0/0.00s] MySQL: [1/0.00s] Graphite: [1/0.00s] RRD: [1/0.00s]Unload poller module ipmi
Load poller module sensors
Checking (snmp) temperature Package id 0…
Checking (snmp) temperature Core 0…
Checking (snmp) temperature Core 1…
Checking (snmp) temperature Core 2…
Checking (snmp) temperature Core 3…
Checking (snmp) temperature Core 4…
Checking (snmp) temperature Core 5…
Checking (snmp) temperature Core 6…
Checking (snmp) temperature Core 7…
31 C
29 C
28 C
28 C
27 C
29 C
28 C
30 C
29 CRuntime for poller module ‘sensors’: 0.0714 seconds with 14496 bytes
SNMP: [1/0.03s] MySQL: [11/0.04s] Graphite: [10/0.00s] RRD: [10/0.00s]Unload poller module sensors
Load poller module processors
Intel Xeon Silver 4110 @ 2.10GHz: 15%
Intel Xeon Silver 4110 @ 2.10GHz: 19%
Intel Xeon Silver 4110 @ 2.10GHz: 21%
Intel Xeon Silver 4110 @ 2.10GHz: 17%
Intel Xeon Silver 4110 @ 2.10GHz: 11%
Intel Xeon Silver 4110 @ 2.10GHz: 14%
Intel Xeon Silver 4110 @ 2.10GHz: 16%
Intel Xeon Silver 4110 @ 2.10GHz: 13%
Intel Xeon Silver 4110 @ 2.10GHz: 10%
Intel Xeon Silver 4110 @ 2.10GHz: 4%
Intel Xeon Silver 4110 @ 2.10GHz: 5%
Intel Xeon Silver 4110 @ 2.10GHz: 12%
Intel Xeon Silver 4110 @ 2.10GHz: 11%Runtime for poller module ‘processors’: 0.1230 seconds with 62384 bytes
SNMP: [2/0.05s] MySQL: [14/0.07s] Graphite: [17/0.00s] RRD: [17/0.00s]Unload poller module processors
Load poller module mempools
hrstorage [system]: Physical memory: 14% 13.17 GiiB / 92.95 GiiB
hrstorage [virtual]: Virtual memory: 41% 77.04 GiiB / 186.7 GiiB
hrstorage [swap]: Swap space: 0% 70 MiiB / 93.75 GiiB
hrstorage [buffers]: Memory buffers: 0% 4.06 MiiB / 92.95 GiiB
hrstorage [cached]: Cached memory: 69% 63.8 GiiB / 92.95 GiiB
hrstorage [shared]: Shared memory: 4% 3.98 GiiB / 92.95 GiiBRuntime for poller module ‘mempools’: 0.0496 seconds with 104928 bytes
SNMP: [1/0.03s] MySQL: [0/0.00s] Graphite: [13/0.00s] RRD: [7/0.00s]Unload poller module mempools
Load poller module storage
Storage /: hrstorage
43%
Storage /dev/shm: hrstorage0%
Storage /run: hrstorage9%
Storage /sys/fs/cgroup: hrstorage0%
Storage /boot: hrstorage3%
Storage /boot/efi: hrstorage1%
Storage /run/user/0: hrstorage0%
Runtime for poller module ‘storage’: 0.0273 seconds with 18064 bytes
SNMP: [1/0.02s] MySQL: [8/0.00s] Graphite: [15/0.00s] RRD: [8/0.00s]Unload poller module storage
Load poller module netstats
ICMP IP IP-FORWARD SNMP TCP TCPHC UDP
Runtime for poller module ‘netstats’: 0.1398 seconds with 3544 bytes
SNMP: [7/0.13s] MySQL: [0/0.00s] Graphite: [86/0.00s] RRD: [6/0.00s]Unload poller module netstats
Load poller module hr-mib
Processes Users
Runtime for poller module ‘hr-mib’: 0.0494 seconds with 3248 bytes
SNMP: [1/0.05s] MySQL: [0/0.00s] Graphite: [3/0.00s] RRD: [3/0.00s]Unload poller module hr-mib
Load poller module ucd-mib
Runtime for poller module ‘ucd-mib’: 0.0343 seconds with 5000 bytes
SNMP: [2/0.03s] MySQL: [0/0.00s] Graphite: [24/0.00s] RRD: [19/0.00s]Unload poller module ucd-mib
Load poller module ipSystemStats
ipv4 ipv6
Runtime for poller module ‘ipSystemStats’: 0.0246 seconds with 17224 bytes
SNMP: [1/0.02s] MySQL: [0/0.00s] Graphite: [33/0.00s] RRD: [3/0.00s]Unload poller module ipSystemStats
Load poller module ports
Caching Oids: Full ports polling ifDescr ifAdminStatus ifOperStatus ifLastChange ifType ifPhysAddress ifMtu ifInErrors ifOutErrors ifInDiscards ifOutDiscards dot3StatsDuplexStatus
Port lo: lo (1 / #371) VLAN = lobps(35.28 Mbps/35.28 Mbps)bytes(155.59 MiB/155.59 MiB)pkts(1.65 Kpps/1.65 Kpps)
Port eno1: eno1 (2 / #372) dot3Duplex VLAN = eno1bps(14.94 Kbps/6.21 Kbps)bytes(67.45 KiB/28.06 KiB)pkts(22.78 pps/2.89 pps)
Port eno2: eno2 (3 / #373) dot3Duplex VLAN = eno2
Port eno3: eno3 (4 / #374) dot3Duplex VLAN = eno3bps(47.49 Kbps/3.65 Mbps)bytes(214.5 KiB/16.12 MiB)pkts(49.3 pps/320.49 pps)
Port enp23s0f0: enp23s0f0 (5 / #375) dot3Duplex VLAN = enp23s0f0bps(1.43 Mbps/50.36 Mbps)bytes(6.3 MiB/222.13 MiB)pkts(1.45 Kpps/4.89 Kpps)
Port eno4: eno4 (6 / #673) dot3Duplex VLAN = eno4bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port enp23s0f1: enp23s0f1 (7 / #674) dot3Duplex VLAN = enp23s0f1bps(2.15 Mbps/93.78 Kbps)bytes(9.5 MiB/423.55 KiB)pkts(205.03 pps/54.3 pps)Runtime for poller module ‘ports’: 0.2782 seconds with 39000 bytes
SNMP: [14/0.22s] MySQL: [14/0.04s] Graphite: [139/0.00s] RRD: [7/0.00s]Unload poller module ports
Load poller module customoid
Runtime for poller module ‘customoid’: 0.0010 seconds with 2448 bytes
SNMP: [0/0.00s] MySQL: [1/0.00s] Graphite: [1/0.00s] RRD: [1/0.00s]Unload poller module customoid
Module [ bgp-peers ] disabled on os.
Module [ junose-atm-vp ] disabled globally.
Module [ printer-supplies ] disabled globally.
Load poller module ucd-diskio
sda sda1 sda2 sda3 dm-0 dm-1
Runtime for poller module ‘ucd-diskio’: 0.0201 seconds with 7872 bytes
SNMP: [1/0.02s] MySQL: [1/0.00s] Graphite: [25/0.00s] RRD: [7/0.00s]Unload poller module ucd-diskio
Module [ wifi ] disabled globally.
Load poller module wireless
Runtime for poller module ‘wireless’: 0.0030 seconds with 168680 bytes
SNMP: [0/0.00s] MySQL: [1/0.00s] Graphite: [1/0.00s] RRD: [1/0.00s]Unload poller module wireless
Module [ ospf ] disabled on os.
Module [ isis ] disabled globally.
Module [ cisco-ipsec-flow-monitor ] disabled globally.
Module [ cisco-remote-access-monitor ] disabled globally.
Module [ cisco-cef ] disabled globally.
Module [ slas ] disabled globally.
Module [ cisco-mac-accounting ] disabled globally.
Module [ cipsec-tunnels ] disabled globally.
Module [ cisco-ace-loadbalancer ] disabled globally.
Module [ cisco-ace-serverfarms ] disabled globally.
Module [ cisco-asa-firewall ] disabled globally.
Module [ cisco-voice ] disabled globally.
Module [ cisco-cbqos ] disabled globally.
Module [ cisco-otv ] disabled globally.
Module [ cisco-qfp ] disabled globally.
Module [ cisco-vpdn ] disabled globally.
Module [ nac ] disabled globally.
Module [ netscaler-vsvr ] disabled globally.
Module [ aruba-controller ] disabled globally.
Load poller module entity-physical
Runtime for poller module ‘entity-physical’: 0.0006 seconds with 2152 bytes
SNMP: [0/0.00s] MySQL: [1/0.00s] Graphite: [1/0.00s] RRD: [1/0.00s]Unload poller module entity-physical
Module [ entity-state ] disabled globally.
Load poller module applications
apache: UUUU…UUU…U…
mysql: .UUUU.UUUUUUUUUU.UU…UUU…UUUU…UUUUU…UU.UUU…U.U.U.UUUU…U.UU…UU…U.
: …Runtime for poller module ‘applications’: 0.7914 seconds with 91256 bytes
SNMP: [4/0.56s] MySQL: [61/0.22s] Graphite: [152/0.00s] RRD: [5/0.00s]Unload poller module applications
Module [ mib ] disabled globally.
Module [ stp ] disabled on os.
Load poller module ntp
Runtime for poller module ‘ntp’: 0.0002 seconds with 400 bytes
SNMP: [0/0.00s] MySQL: [0/0.00s] Graphite: [1/0.00s] RRD: [1/0.00s]Unload poller module ntp
Module [ loadbalancers ] disabled globally.
Module [ mef ] disabled globally.
Load poller module mpls
Runtime for poller module ‘mpls’: 0.0004 seconds with 23880 bytes
SNMP: [0/0.00s] MySQL: [0/0.00s] Graphite: [1/0.00s] RRD: [1/0.00s]Unload poller module mpls
Enabling graphs:
Polled in 2.714 seconds
Start Device Groups
End Device Groups, runtime: 0.0056s
Start Alerts
End Alerts
SNMP [38/1.21s]: Get[12/0.46s] Getnext[4/0.06s] Walk[22/0.69s]
MySQL [123/0.39s]: Cell[1/0.00s] Row[-1/-0.00s] Rows[16/0.01s] Column[1/0.00s] Update[105/0.38s] Insert[1/0.00s] Delete[0/0.00s]
Graphite [533/0.01s]: Write[533/0.01s]
RRD [108/0.01s]: Update[108/0.01s]
I already deleted the RRD files and did a new discover.
