We are having issues with our LibreNMS server consuming all of the CPU. A reboot of the server resolves it temporarily and then it grows back to consume the CPU. Running top shows that mysqld is the culprit.
If I run SHOW FULL PROCESSLIST, it starts off a dozen processes and grows from there. THe highest I have seen so far is 76 processes. A lot of them seem to be DELETE statements from the ipv4 mac table.
I checked the info on this table and it is estimated to be about 1.1 GB in size .
SELECT COUNT(*) FROM ipv4_mac; shows 12,107,446 rows and is growing each time I run the command.
Is there any reason that this table should be this big and is there a way to clean it up? Or am I looking in the wrong place for performance issues?
Monitoring:
82 systems
approx 1600 ports
approx 400 sensors (might have counted those wrong)
Component
Version
LibreNMS
1.35-107-gbdf02f1
DB Schema
230
PHP
7.0.22-0ubuntu0.16.04.1
MySQL
10.0.33-MariaDB-0ubuntu0.16.04.1
RRDTool
1.5.5
SNMP
NET-SNMP 5.7.3
I have also found by sorting the contents of the ipv4_mac table that there are many duplicate rows.
There are also many rows with identical IP addresses and mac addresses but different device_id and port_id. Not sure if this helps or not.
I noticed that all of the “duplicates” have a context_name = null in the ipv4_mac table
Also the ipv4_address is not the IP address of the device ID (but this might be normal since I do not know what this data is used for)
I ran the command you posted on 4 different deviceIDs
