MySQL High CPU Usage
I have LibreNMS and i have problem with MySQL, service reach 700% CPU and I can’t optimize him.
On MySQL i have only Libre database.
This is VM on VMWare
Spec:
12CPU
24GB RAM
SSD
Ubuntu 20.04.1 LTS
Show processlist; don’t show any suspicious query.
Below is my cnf file
# These groups are read by MariaDB server.
# Use it for options that only the server (but not clients) should see
# See the examples of server my.cnf files in /usr/share/mysql
# this is read by the standalone daemon and embedded servers
[server]
# this is only for the mysqld standalone daemon
[mysqld]
# * Basic Settings
user                    = mysql
pid-file                = /run/mysqld/mysqld.pid
socket                  = /run/mysqld/mysqld.sock
#port                   = 3306
basedir                 = /usr
datadir                 = /var/lib/mysql
tmpdir                  = /tmp
lc-messages-dir         = /usr/share/mysql
skip-external-locking
innodb_file_per_table=1
lower_case_table_names=0
innodb_lru_scan_depth=100
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address            = 127.0.0.1
default-time-zone = "+02:00"
# * Fine Tuning
key_buffer_size        = 100M
max_allowed_packet     = 256M
thread_stack           = 192K
thread_cache_size      = 100
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched
#myisam_recover_options = BACKUP
max_connections        = 300
#table_cache            = 64
#thread_concurrency     = 10
# * Query Cache Configuration
#query_cache_limit      = 1M
query_cache_size        = 16M
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
# As of 5.1 you can enable the log at runtime!
#general_log_file       = /var/log/mysql/mysql.log
#general_log            = 1
# Error log - should be very few entries.
log_error = /var/log/mysql/error.log
# Enable the slow query log to see queries with especially long duration
#slow_query_log_file    = /var/log/mysql/mariadb-slow.log
#long_query_time        = 10
#log_slow_rate_limit    = 1000
#log_slow_verbosity     = query_plan
#log-queries-not-using-indexes
# The following can be used as easy to replay backup logs or for replication.
# note: if you are setting up a replication slave, see README.Debian about
#       other settings you may need to change.
#server-id              = 1
#log_bin                = /var/log/mysql/mysql-bin.log
expire_logs_days        = 10
max_binlog_size        = 100M
#binlog_do_db           = include_database_name
#binlog_ignore_db       = exclude_database_name
# * Security Features
# Read the manual, too, if you want chroot!
#chroot = /var/lib/mysql/
# For generating SSL certificates you can use for example the GUI tool "tinyca".
#ssl-ca = /etc/mysql/cacert.pem
#ssl-cert = /etc/mysql/server-cert.pem
#ssl-key = /etc/mysql/server-key.pem
# Accept only connections using the latest and most secure TLS protocol version.
# ..when MariaDB is compiled with OpenSSL:
#ssl-cipher = TLSv1.2
# ..when MariaDB is compiled with YaSSL (default in Debian):
#ssl = on
# * Character sets
# MySQL/MariaDB default is Latin1, but in Debian we rather default to the full
# utf8 4-byte character set. See also client.cnf
character-set-server  = utf8mb4
collation-server      = utf8mb4_general_ci
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
# * Unix socket authentication plugin is built-in since 10.0.22-6
# Needed so the root database user can authenticate without a password but
# only when running as the unix root user.
# Also available for other users if required.
# See https://mariadb.com/kb/en/unix_socket-authentication-plugin/
# this is only for embedded server
[embedded]
# This group is only read by MariaDB servers, not by MySQL.
# If you use the same .cnf file for MySQL and MariaDB,
# you can put MariaDB-only options here
[mariadb]
# This group is only read by MariaDB-10.3 servers.
# If you use the same .cnf file for MariaDB of different versions,
# use this group for options that older servers don't understand
[mariadb-10.3]
I don’t know what parameters I must change, please help me.
Perhaps you should post the show processlist output.
