I got a really weird problem.
I had extended the snmpd.conf on several hosts to monitor the MySQL instances.
Graphs show up like expected except on the LibreNMS host itself.
Credentials for the script located in “/etc/snmpd/” are settled in a file called “mysql.cnf”.
When I run the script as user librenms values are pulled from MySQL
bash-4.2$ cd /etc/snmp/
bash-4.2$ ./mysql
a0:0
a1:0
a2:0
a3:0
eh:24474624
ei:134217728
ej:0
ek:0
bash-4.2$
But graphs on the UI are not populated.
./poller.php -h 1 shows following about the applications:
#### Load poller module applications ####
apache: UUUUUUUUUU...U......
memcached(): ..................
mysql: UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
ntp-client: U....
rrdcached: .UUUU..U.
Any idea what’s going on here?
HI @Jarod2801,
As always, ./validate.php your install.
Then, if everything is ok, run ./poller.php -d -h 1 -m applications
and check the output or pastebin if you dont find any problem.
Shame on me having forgot the validate.php
LibreNMS | 1.42.01-78-g6d62026
DB Schema | 260
PHP | 7.0.31
MySQL | 5.5.60-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.7.2
[FAIL] Missing PHP extension: mysqlnd
[FIX] Please install mysqlnd
[FAIL] The poller (xyz-librenms) has not completed within the last 5 minutes, check the cron job.
I replace php70w-mysql with php70w-mysqlnd.
Now validate.php shows no errors any more.
I will have a look on the graphs later as I have to leave now.
Thanks a lot!!!
Works!
Thank you for your help.
