Hello.
I’m trying to install LibreNMS to migrate from Observium. The plan is to use my existing MySQL cluster which requires TLS for communication.
The installation guide asks to go through online install (http[s]://<instance/install) to generate configuration. However the installer does not have any fields to configure TLS and it fails with “SQLSTATE[HY000] [2026] SSL connection error: SSL is required from client”.
I’ve tried to update .env file with:
DB_SSLMODE=require
MYSQL_ATTR_SSL_CA=
But it doesn’t look like installer picks up this configuration.
So first of all, is MySQL with TLS supported at all?
Secondly how do I configure it? Do I skip the installer (what to configure manually then?)? Or how do I convince the installer to use the encryption?
