At some point in the last 12 hours our LibreNMS install stopped be able to poll all devices in time, gappy graphs etc.
A quick glance at top, and mysqld is being a cpu hog, and i’m only occasionally not able to connect to the DB. - Previously been running for about a month, and a reboot hasn’t helped anything
Component |
Version |
LibreNMS |
1.52-50-gcfc51d51f |
DB Schema |
2019_05_30_225937_device_groups_rewrite (135) |
PHP |
7.2.19-0ubuntu0.18.04.1 |
MySQL |
10.1.40-MariaDB-0ubuntu0.18.04.1 |
RRDTool |
1.7.0 |
SNMP |
NET-SNMP 5.7.3 |
[OK] Composer Version: 1.8.6
Devices:
Devices removed
and 317 more…
Thanks in advance for your help!
Run updates again it was the device groups update that didnt work. the update removes it.
Ok cool, I ran ./daily.sh and got the below -
Updating Composer packages OK
Updated from cfc51d51f to 2da6c8104 OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Now validate.php brings up the below…
Component |
Version |
LibreNMS |
1.52-52-g2da6c8104 |
DB Schema |
PHP |
MySQL |
RRDTool |
1.7.0 |
SNMP |
NET-SNMP 5.7.3 |
[WARN] Your database schema has extra migrations (2019_05_30_225937_device_groups_rewrite). If you just switched to the stable release from the daily release, your database is in between releases and this will be resolved with the next release.
[FAIL] Database: incorrect column (device_groups/desc)
[FAIL] Database: missing column (device_groups/params)
[FAIL] Database: extra column (device_groups/type)
[FAIL] Database: extra column (device_groups/rules)
[FAIL] We have detected that your database schema may be wrong, please report the following to us on Discord (https://t.libren.ms/discord) or the community site (https://t.libren.ms/5gscd):
SQL Statements:
ALTER TABLE device_groups
CHANGE desc
desc
varchar(255) NOT NULL DEFAULT ‘’ ;
ADD params
text NULL AFTER pattern
DROP type
DROP rules
Devices:
Anything else other than the suggested SQL statements I should make or be concerned by? The Libre GUI is starting to look more normal again, although polling hasn’t caught up with itself
Switched myself over to the monthly update for now - All looks to be back to normal, thanks for the help!
Chris
