Nagios plugin and dashboard
How do I show nagios plugin service “Self define name” on dashboard??
I try to show sysName and Hostname on availability-map but always showing program name that in nagios plugin forder
Please help~~
Many Thanks…:rofl:
Hi Sir
I find the soluting that modify the availability-map.blade.php.
In this file, the variable has the Name string that nagios plugin Service.
Modifying it with PHP string function and it will display the Nagios Service name in availability map .
Many Thanks~
