I’m having issues with polling Fortigate devices. I notice 1 of the SNMP commands failing because cluster and HA sync status is configured wrong here. The index is in place of the OID and the numerical OID is missing.
Now I can branch and request an MR to fix this but I was wondering if I’m correct and if there’s something wrong in my setup. Shouldn’t name based polling work?
This is what happens in the log:
SNMP['/usr/bin/snmpget' '-v3' '-l' 'authPriv' '-n' "" '-a' 'SHA' '-A' 'PASSWORD' '-u' 'USER' '-x' 'AES' '-X' 'PASSWORD' '-OUQnte' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/fortinet' '-t' '3' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.12356.101.12.2.3.1.1.1' '.1.3.6.1.4.1.12356.101.12.2.2.1.20.1.12' '.1.3.6.1.4.1.12356.101.12.2.2.1.20.3.1' 'fgHaSystemMode.0' 'fgHaStatsEntry']
Exitcode: 1
If I perform the command manually and append -m FORTINET-FORTIGATE-MIB it works. Does that mean there’s something wrong in the command LibreNMS performs? I notice the mib directory getting included but it seems it does not have any use.
