Hi All,
Please see this screenshot of my Librenms install. After the latest update my navigation bar has disappeared from the web interface.
I have tried multiple web browsers (Chrome,Edge Chromium and IE) with the same result. If I right click and inspect element I have the following error in the console. It looks unrelated.
ncaught Error: Map container is already initialized.
at e._initContainer (:5:40678)
at e.initialize (:5:29595)
at new e (:5:14732)
at Object.t.map (:5:140239)
at Array. (:5:21)
at Object.success (librenms.js?ver=05072021:242)
at c (jquery.min.js?ver=05072021:2)
at Object.fireWith [as resolveWith] (jquery.min.js?ver=05072021:2)
at l (jquery.min.js?ver=05072021:2)
at XMLHttpRequest. (jquery.min.js?ver=05072021:2)
DevTools failed to load source map: Could not load content for https:///leaflet.markercluster.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
Here is the output of My ./Validate.php
Component | Version |
LibreNMS | 21.6.0-54-g1a97559 |
DB Schema | 2021_06_07_123600_create_sessions_table (211) |
PHP | 7.4.21 |
Python | 3.6.8 |
MySQL | 10.5.11-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 2.1.3
Server seems healthy with no excessive load , disks have plenty of space and nothing seems out of the ordinary.
