Need help, Cannot move past DB migration! Thank you!
Hello, I have been struggling with this error on and off for a very long time and after today, I noticed that my Librenms web UI will not even load until I can finally get the migrate command to complete, i think it’s because my site upgraded, and my DB is far behind. but I’ve been pulling my hair out and I cannot get it to move past this. I’ve done everything I can think of including running it in -pretend and then running the SQL commands manually, but they do not help me move past this. how can I skip this particular migration script since I did it manually?
Thanks!
Output of validate:
-bash-4.2$ ./validate.php
LibreNMS  | 23.10.0-66-gf59388d (2023-11-11T13:19:42-06:00)
DB Schema | 2021_11_29_165046_improve_devices_search_index (225)
PHP       | 8.1.25
Python    | 3.6.8
Database  | MariaDB 10.5.17-MariaDB
RRDTool   | 1.4.8
SNMP      | 5.7.2
[OK]    Composer Version: 2.6.5
[FAIL]  Your database is out of date!
        ./lnms migrate
Attempt to fix this issue (y or n)?:y
In Connection.php line 795:
  SQLSTATE[42000]: Syntax error or access violation: 1061 Duplicate key name 'ports_ifalias_port_descr_descr_portname_index' (Connection: mysql, SQL: alter table `ports` add index `ports_ifalias_port_descr_descr_portname_index`(`ifAlias`, `port_
  descr_descr`, `portName`))
In Connection.php line 580:
Output of migrate command:
-bash-4.2$         ./lnms migrate
        APPLICATION IN PRODUCTION.
  Do you really wish to run this command? (yes/no) [no]
❯ yes
   INFO  Running migrations.
  2021_11_29_165436_improve_ports_search_index ............................................................................................ 2ms FAIL
If I try to drop the index manually, then run it again, it complains that the index does not exist. I am stuck in a loop and could really appreciate any and all assistance. Thanks!
Look in your database and remove the duplicate port ifAlias, port_descr_descr, portName combo.
