Im using librenms for past 3 months and i have installed osTicket in the same server and need to raise a ticket in osticket ex: if the device is down
Hi @SG_Krishnan
You have an “API Transport” in LibreNMS you can bind to your “Device down” alert, and use whatever API OSTicket provides to create a ticket. Can even be on a different server if necessary.
Bye
Hi @PipoCanaja,
i have tried to do that but it’s not working
i think im missing something in here
and can you help with sharing a link for the instructions if you have?
Hi @SG_Krishnan
Unfortunately not, I have no clue about osticket. On LibreNMS side, the doc is here.
https://docs.librenms.org/Alerting/Transports/#api
Bye
