| LibreNMS | 23.2.0-30-g0e322ae5d (2023-03-13T20:49:23+05:30) |
| DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (248) |
| PHP | 8.2.3 |
| Python | 3.9.2 |
| Database | MariaDB 10.5.18-MariaDB-0+deb11u1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9 |
[OK] Composer Version: 2.5.4
“Exception: Using ${var} in strings is deprecated, use {$var} instead”
“/opt/librenms/LibreNMS/Validations/Database/CheckSchemaStructure.php:267”
“/opt/librenms/LibreNMS/Validations/Database/CheckSchemaStructure.php:277”
[OK] MySQl and PHP time match
“Exception: stream_socket_client(): Unable to connect to tcp://127.0.0.1:6379 (Connection refused)”
“/opt/librenms/vendor/predis/predis/src/Connection/StreamConnection.php:127”
“Exception: rtrim(): Passing null to parameter #1 ($string) of type string is deprecated”
“/opt/librenms/LibreNMS/Validations/User.php:95”
“Exception: Creation of dynamic property Facade\FlareClient\Http\Client::$lastRequest is deprecated”
“/opt/librenms/vendor/facade/flare-client-php/src/Http/Client.php:184”
soon i enabled syslog-ng these issue occured
anyone know how to fix it
