Trying to monitor a remote server for the first time using snmp V3. Librenms is giving me this when I try to connect:
Adding SNMPv3 host: xx.xx.xx.xx port: 161
Could not connect to xx.xx.xx.xx, please check the snmp details and snmp reachability
SNMP v3: No reply with credentials mypassword/authPriv
SNMP v3: No reply with credentials root/noAuthNoPriv
I am using thes entries when adding the device:
Hostname or IP xx.xx.xx.xx
SNMP Version v3
Port 161 udp
Port Association Mode: ifIndex
SNMPv3 Configuration
Auth Level: authPriv
Auth User Name: MyUser
Auth Password: MyPass
Auth Algorithm: SHA-512
Crypto Password: MyPrivPass
Crypto Algorithm: AES
This is my /etc/snmpd.conf (with commented lines removed):
sysLocation Location, USA [xxxx,-yyyy]
sysContact SysOps <[email protected]>
sysServices 72
master agentx
agentAddress udp:161
view all included .1
createUser MyUser SHA-512 MyPass AES MyPrivPass
rouser MyUser authpriv
I have confirmed on the remote server with nmap that port 161 is open, and that snmpd is running.
Any help is appreciated…
