Netapp Missing CPU and Network Graph
the Netapp monitoring does not show CPU graphs or network graphs. Also the MIB is quite outdated.
I could provide latest MIB file 2.13 instead of 2.4 (currently used)
regards
Marc
If you can provide the MIB. I can integrate that in lnms
Hi Cormoran,
not sure what you mean, but currently the discovered Netapp only show storage related information (like how much space is used in an aggregate and volume…) What I would like to see as well is the CPU Usage (quite important as well) and the networks stats (Ethernet and FC) if that is possible.
Regards
Marc
I update the mib file in librenms. Now you can update your instance and see if it changes something
Hi, ah - understand. Unfortunately it does not change anything. It still only shows storage parameters but no CPU/Network/FC stats. Is there anything else that needs to be done? Sry - I am not so experienced with SNMP.
Hi, updating a MIB file doesn’t change anything unfortunately, it’s simply a “dictionary” for the snmp data.
Someone needs to contribute an integration for it
Hi Jellyfrog, thanks for the information. About the integration is that something easy to do - like going though a documentation and selecting what graphs/values I want to have or something somebody with more knowledge than myself has to volunteer?
Thanks Jellyfrog for the response.
@bartman71 you can run discovery.php and poller and snmwalk like this:
./discovery.php -d -h HOSTNAME
./poller.php -h HOSTNAME -r -f -d
snmpbulkwalk -OUneb -v2c -c COMMUNITY HOSTNAME .
to give us the necessary information
many thanks for all your support so far. Here is the link for the required files - I redirected the output to files:
Is there any update regarding this problem? I’m on the following version of LibreNMS Version 22.2.1, but I got the same problem, CPU and Network Graphs are missing.
This issue seems persistent in the current release of LibreNms.
How is it possible to fix it ?
Regards.
this is the latest MIB for NetApp ONTAP 9: Jottacloud
