Problem description:
Hi All, LibreNMS works fine with stand alone GS724v4 switches but when switches are part of a stack, interface data graphs are empty.
Please, anyone with a helpful suggestion? …
I saw this either with Chrome or IE11 but I don’t believe it is a browser related problem.
OS: Ubuntu 16.04 using latest LibreNMS version
Thank you
Regards,
Jose
pastebin.com the output of ./validate.php
and
./poller.php -h HOSTNAME -d
./discovery.php -h HOSTNAME -d
Hi Kevin,
Thank you for your help.
Apologies for late response but I don’t have always access to that LibreNMS. Just got this information yesterday.
Files are quite big I attached links to poller.php and discovery.php output files:
https://drive.google.com/file/d/1KbC3TLf_SISO-3jGXEFEuepHFO2JUw0r/view?usp=sharing
https://drive.google.com/file/d/1oiq_-Q_JZOCP1nEhk3vOaNhGFeYaY0oe/view?usp=sharing
I just noticed that I forgot the ./validate.php. will upload it ASAP.
Best regards,
Jose:
Hi Kevin,
Apologies for delay.
I attached here validate.php:
Component |
Version |
LibreNMS |
1.40-36-gc6fc763 |
DB Schema |
252 |
PHP |
7.0.30-0ubuntu0.16.04.1 |
MySQL |
10.0.34-MariaDB-0ubuntu0.16.04.1 |
RRDTool |
1.5.5 |
SNMP |
NET-SNMP 5.7.3 |
[e[32mOKe[0m] Composer Version: 1.6.5
[e[32mOKe[0m] Dependencies up-to-date.
[e[0;32mOKe[0m] Database connection successful
[e[0;32mOKe[0m] Database schema correct
[e[1;31mFAILe[0m] You have no timezone set for php.
[e[1;34mFIXe[0m] e[1;34mhttp://php.net/manual/en/datetime.configuration.php#ini.date.timezonee[0m
[e[1;33mWARNe[0m] Your install is over 24 hours out of date, last update: Tue, 26 Jun 2018 22:29:52 +0000
[e[1;34mFIXe[0m] e[1;34mMake sure your daily.sh cron is running and run ./daily.sh by hand to see if there are any errors.e[0m
[e[1;31mFAILe[0m] You need to run this script as root or librenms
Thank you in advance for your help.
Regards,
Jose
Hi Kevin,
Now with root permissions:
Component |
Version |
LibreNMS |
1.40-36-gc6fc763 |
DB Schema |
252 |
PHP |
MySQL |
RRDTool |
1.5.5 |
SNMP |
NET-SNMP 5.7.3 |
Best regards,
Jose
Hi Kevin, Hi All,
Please, could someone help me with this issue?
Many, many thanks in advance for your understanding and help.
Best regards,
Jose
Dear Community,
Best regards,
Jose
