Hardware: WS-12-400-AC
Operating System Netonix 1.4.6
Adding a new device or using an existing device does not matter. Another Netonix with the same Hardware & OS appears to be graphing / displaying port info correctly. previous revision of 1.4.5rc8 does not correct the issue
Tested other models / firmware same results. ex;
Hardware:WS-12-250-AC
Operating System: Netonix 1.4.7rc14
Picture showing semi-working + event log. Note the changed from 0 to 2 - appears to be port 5 ( working / displaying correcetly ) and for some reason - graph data for ports that have poe turned off.
Hey, so I just ran into this myself, and I’ve developed a fix.
The existing netonix.inc.php file does not correctly map all 5 possible PoE states, and doesn’t match the coding style / template used in other sensor state files.
There are 5 possible states; Off, 24V, 48V, 24VH, 48VH. the H in 24VH/48VH indicates “High Power” or 4-pair PoE mode, where all 4 pairs of the cable are used to supply power. The vast majority of PoE devices do not use this; it’s mostly found on wireless equipment such as Ubiquiti AirFiber radios, and if used with an incompatible device will usually fry the port & device.
The new status map has Off/24V/48V as 1/2/3 to maintain compatibility with the old map, and adds 24VH and 48VH as 4/5 respectively.
I’ve changed the name of the state index from netonixPoeStatus to netonixPoeState as I had issues with the code not updating the state index. I’m unsure how to clean this up; as a result of my testing I actually have three separate indexes… If someone could let me know how to un-derp that, that’d be great…
Anyway, I’ve got a branch here (pull request shortly) that fixes it.
