Is there anyway to get the Network Map to have more detailed information? Like when a cisco switch is port channeled it just shows connected via vlan 10 and not what ports (hardware) are being port channeled.
Also is there a way to expand the map or have it find hops after just the first hop. Trying to draw out a map and trace from a specific device.
Thank You
