I have an issue similar to what is outlined here - and I have tried the config.php modification captured in that thread … but it seems to not be working for me? Here is what I see (example port) when I set $config['os']['windows']['ifname'] = true;
in config.php,
Some “odd” name => I’d like the connection to be called Ethernet (MB)
, just like it is in Windows. So then I tried changing to $config['os']['windows']['ifname'] = false;
in config.php, and I get,
Hmmm … OK, how to get the name to be Ethernet (MB)
… again, like it is in Windows. I did also check, and from snmp (walk),
IF-MIB::ifAlias.9 = STRING: Ethernet (MB)
OK, so I just want ifAlias to be used for the Port name. Is there a way to do that?
Thanks!
