New GuzzleHttp does not honor proxy settings
Observed behaviour:
The new GuzzleHTTP Client code in LibreNMS/Alert/Transport/Api.php, introduced with PR #10070 does not honor proxy settings.
Thus breaking Api notifications in environments requiring a proxy.
Expected behaviour:
The new GuzzleHTTP Client code in LibreNMS/Alert/Transport/Api.php honors proxy setting from environment or config.php.
Validate output:
Note: Api.php has manually been modified with a workaround for said problem
LibreNMS 1.56
DB Schema 2019_09_05_153524_create_notifications_attribs_index (141)
PHP 7.2.19
MySQL 5.5.60-MariaDB
RRDTool 1.6.0
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.9.0
Modified Files:
Files:
/opt/librenms/storage/framework/views/02ea8d160e2d0303d6da3babaec7627a
Hi @kleinem86
Could you submit a PR with the fix for this ? We’ll be happy to review it and merge it for others using a proxy.
Thanx
sorry i’m afraid providing a proper/clean fix myself is beyond my skills.
My workaround basically just hardcodes the proxy i’m using into the existing api.php file, into the argument array format guzzlehttp expects.
This can be found here:
http://docs.guzzlephp.org/en/stable/request-options.html#proxy
I guess one would have to wrap a simple “if” clause around it to check if a proxy is globally set.
Regards
