New install, two issues after running validation
I always seem to have a problem with timezones. I’m either not understanding what needs to be done or making a mistake with my entries/syntax.
Ensure date.timezone is set in php.ini to your preferred time zone.
See http://php.net/manual/en/timezones.php for a list of supported timezones. Valid examples are: “America/New_York”, “Australia/Brisbane”, “Etc/UTC”.
vi /etc/php/7.2/apache2/php.ini
vi /etc/php/7.2/cli/php.ini
I opened both of those files with vi and searched for date.timezone and added “America/Chicago” in each file. I did this during the install. Running validation I get the error above.
Is there a 3rd (or more) php.ini file(s)? If so, where are they located?
Git Hub issue (resolved)
Warning: Your local git contains modified files, this could prevent automatic updates.
Fix: You can fix this with ./scripts/github-remove
When I run sudo ./scripts/github-remove I get this, ./scripts/github-remove: command not found
When I run -bash: ./scripts/github-remove I get ./scripts/github-remove: No such file or directory
Another question that I have to ask since visiting the site, today. I see a banner stating:
Users of daily updates (the default), your installs will no longer update without a little manual intervention.
It will not be an issue for those on the monthly updates.
You will need to update LibreNMS manually to resolve the issue.
su - librenms
git pull
./daily.sh
I assume this is something I need to run, as well, or will validation tell me if I need to do anything else?
Thanks.
Edit- Fixed the git hub issue, I was in /opt not in /opt/librenms.
Here is where I’m currently at. Last time I asked about this I still wasn’t able to fix it, but I’ll give it another shot if I can get some assistance. Obviously I’m missing something.
LibreNMS 1.58.1-21-gb555edee5
DB Schema 2019_10_03_211702_serialize_config (147)
PHP 7.2.24-0ubuntu0.18.04.1
MySQL 10.1.43-MariaDB-0ubuntu0.18.04.1
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 1.9.1
[FAIL] You have no timezone set for php.
http://php.net/manual/en/datetime.configuration.php#ini.date.timezone
Hi.
Here are the files where I got my timezone set:
date.timezone = Europe/Warsaw
Check what PHP version you have enabled, or try by:
librenms:[/etc]php -v
PHP 7.2.24-1+0~20191026.31+debian9~1.gbpbbacde (cli) (built: Oct 26 2019 14:18:28) ( NTS )
Then make sure you got Apache Mod 7.2 enabled (maybe you are still running 7.0)?
@limes-github I didn’t see this post until now. Before I saw this, I tried editing the timezone by running a specific time zone command which caused mysql errors the next time I tried to validate. If someone can help correct this mysql error, I’d appreciate that. While the validate file does tell me which mysql statements to run, I’m not sure how/where to run those statements.
This is the timezone command I ran: cp /usr/share/zoneinfo/America/Chicago /etc/localtime
Here is the mysql fix:
ALTER TABLE notificationsCHANGEdatetime datetime timestamp NOT NULL DEFAULT '1970-01-02 00:00:00' ;
and
ALTER TABLE usersCHANGEcreated_at created_at timestamp NOT NULL DEFAULT '1970-01-02 00:00:01' ;
Anyone? I’d like to avoid a rebuild. Thank you.
Whats the output of this;
date +%Z
php -r "echo date('T');"
@Chas
date +%Z
Am I running those are separate commands? If so, I see CST for both.
Thanks.
