New OS polling/discovery problem
Hello!
I’m trying to add new OS but after ~5 minutes after add a device (or after device discovery process) the device dashboard losts CPU and sensors data.
Device dashboard screentshots:
Text outputs:
As an example you can see in discovery output
ARICENT-ISS-MIB::issSwitchCurrentTemperature.0 = 28
but in poll process
Checking (snmp) temperature Current Temperature...
0 C
How can I fix it? Thanks.
I think it might be you’re missing the leading dot ‘.’ in the processor and temperature num_oid lines. Non-obvious, but has caught me before.
    processors:
        data:
                oid: eltMesIssCpuUtilLastMinute
                num_oid: '1.3.6.1.4.1.35265.1.139.6.1.1.2.2'
        temperature:
            data:
                    oid: ARICENT-ISS-MIB::issSwitchCurrentTemperature
                    value: ARICENT-ISS-MIB::issSwitchCurrentTemperature
                    num_oid: '1.3.6.1.4.1.2076.81.1.66.0'
See this similar one: New OS - Data shows in Discovery but not in poller
Basically that means the num_oid value you are storing isn’t correct, that’s only used for polling not discovery.
Your discovery pastebin has expired and your polling one doesn’t have debug enabled.
Thank you. The leading dot fixed the issue.
