this ping seting is right or wrong suggest me proper setings to fix this problem
I would default back to the standard ping settings by clicking the refresh icon. Relying on 1 ping isn’t ideal, the default is 3.
It should say in the log why the device is showing as down, either icmp or snmp, when you have that info you can then check manually from the librenms box if you can access the device via pinging it or via snmp.
