I’ll try piggy-backing on this…I’ve installed NFSEN independently of LibreNMS / different machine with RRD’s exported and mounted on LibreNMS machine via fstab.
I get the “netflow” tab on the devices and I get statistics but no graphs.
I’ve moved your topic to a new one.
Are you running rrdcached? Does librenms have read permissions for that mount?
thank you. I’m running RRDCACHED on my librenms box but not on the nfsen box. I could set it up on the nfsen box if it would make everything easier.
good thought on the librenms user…I didn’t even think of that…take pity on me I’ve been a windows guy for so long. On my nfsen box I have the exports set to this:
opt/nfsen IP_OF_MY_LIBRENMS_HOST/32(rw,nohide)
which, if I understand the basics of NFS, it doesn’t matter which UID from MY_LIBRENMS_HOST mounts /opt/nfsen - it should have read and write.
on my librenms machine, I have this set in fstab
my_NFSEN_IP:/opt/nfsen /media/nfsen nfs rsize=8192,wsize=8192,timeo=14,_netdev 0 0
in my librenms config I have the following:
##########NFSEN##############
$config['nfsen_enable'] = 1;
$config['nfsen_split_char'] = '_';
$config['nfsen_rrds'][] = '/media/nfsen/profiles-stat/live/';
$config['nfsen_rrds'][] = '/media/nfsen/profiles-stat/';
$config['nfsen_base'][] = '/media/nfsen/';
$config['nfdump'] = '/usr/bin/nfdump';
$config['nfsen_last_max'] = 153600;
$config['nfsen_top_max'] = 500;
$config['nfsen_top_N']=array( 10, 20, 50, 100, 200, 500 );
$config['nfsen_top_default']=20;
$config['nfsen_stat_default']='srcip';
$config['nfsen_order_default']='packets';
$config['nfsen_last_default']=900;
$config['nfsen_lasts']=array(
'300'=>'5 minutes',
'600'=>'10 minutes',
'900'=>'15 minutes',
'1800'=>'30 minutes',
'3600'=>'1 hour',
'9600'=>'3 hours',
'38400'=>'12 hours',
'76800'=>'24 hours',
'115200'=>'36 hours',
also, we do use IP for all of our librenms targets, so I did create a pointer for 10_10_11_1 on the nfsen box for 10.11.1.1
No, you dont have to install rrdcached on nfsen box.
Does your rrdcached run with -B flag? if yes, remove it. (Capital B)
I wasn’t sure how to take off the -B flag. I stopped rrdcached and then I disabled it in my librenms config.
Graphs are working…but rrdcached isn’t. hahaha. I’m figuring it’s in init.d somewhere but I haven’t dug yet.
systemctl status rrdcached
Take the Loaded: line
Edit that file (the -B will be probably there)
@TheGreatDoc
perfect…that was it. Odd thing is the /etc/init.d/rrdcached file had the options greyed out almost like they weren’t enabled and were comments. Thank you so much for the assistance, very much appreciated.
