Hi there!
I’m configuring Nfsen in LibreNMS, and I got everything working. I have 3 different devices sending netflows, getting the flows and the graphs into NFSEN window.
The problem is that in LibreNMS, inside the device Netflow tab, I can see the flows in the Stats sub tab , but not able to see the graphs, nothing appears:
Do someone know what may it happen? Is that a permissions problem? That’s the only piece missing to get everything working.
| Component |
Version |
| LibreNMS |
1.58.1 |
| DB Schema |
2019_08_10_223200_add_enabled_to_users (147) |
| PHP |
7.2.24-0ubuntu0.18.04.1 |
| MySQL |
10.1.43-MariaDB-0ubuntu0.18.04.1 |
| RRDTool |
1.7.0 |
| SNMP |
NET-SNMP 5.7.3 |
Many thanks
I decided to write here instead of opening new topic.
My NFSen instance works well (available through WWW, all graphs, stats are there. Functional 100%).
But in LibreNMS it look like this:
I have ‘Stats’ button, therefore I cannot use nfdump via LibreNMS (cannot look into flows - results are empty). This is how my “NFSen” part looks in the config.php:
$config[‘nfsen_enable’] = 1;
$config[‘nfsen_split_char’] = ‘_’;
$config[‘nfsen_rrds’] = ‘/opt/nfsen/profiles-stat/live/’;
$config[‘nfsen_base’] = ‘/opt/nfsen/’;
$config[‘nfsen_suffix’] = ‘_my_domain_here_com’;
$config[‘nfsen_last_max’] = 115200;
$config[‘nfsen_top_max’] = 500;
$config[‘nfsen_top_N’] = array( 10, 20, 50, 100, 200, 500 );
$config[‘nfsen_top_default’] = 20;
$config[‘nfsen_stat_default’] = ‘srcip’;
$config[‘nfsen_order_default’] = ‘packets’;
$config[‘nfsen_last_default’] = 900;
$config[‘nfsen_lasts’] = array(‘300’ => ‘5 minutes’, ‘600’ => ‘10 minutes’, ‘900’ => ‘15 minutes’, ‘1800’ => ‘30 minutes’, ‘3600’ => ‘1 hour’, ‘9600’ => ‘3
hours’, ‘38400’ => ‘12 hours’, ‘76800’ => ‘24 hours’, ‘115200’ => ‘36 hours’, ‘153600’ => ‘48 hours’);
Permissions seems fine, I tried declaring the:
$config[‘nfdump’] = ‘/usr/bin/nfdump’;
But it didn’t help.
Can anyone point me to the right direction?
Just in case:
LibreNMS | 1.59-7-g13c6309e8
DB Schema | 2019_12_16_140000_create_customoids_table (152)
PHP | 7.2.26-1+0~20191218.33+debian9~1.gbpb5a34b
MySQL | 10.1.41-MariaDB-0+deb9u1
RRDTool | 1.6.0
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.9.1
Update. Manual does not inform about having to make a symbolic link also in NFSen directory for profiles-data.
Solution:
cd /opt/nfsen/profiles-data/live
ln -s YOUR_SOURCE_NAME YOUR_DEVICE_NAME_IN_LIBRE
In my case:
ln -s juniper 100_100_100_100 (it’s it’s IP number).
Cheers
Bringing back an old thread… to be clear on the solution above, if the device source in nfsen.conf is firebox, the device in librenms has been added with an ip address of 10.0.1.1 and the output to /var/nfsen/profiles-stat/live/ is firebox.rrd I would create a symlink ln -s firebox.rrd 10_0_1_1.rrd to get librenms to read the graphs?
